Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
The unit powers up, and emits a couple of beeps. It then sits at a "Please Wait" message, and the toner light is on. After that, nothing happens. The display does not react to any changes. Ideas? Thank you.
    New Friend:
  • 116 Answers
MAY BE MAIN PCB PROBLM
Posted on Jul 23, 2009
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
The "ready" and "alarm" light
Please do the cleaning of DRUM unit by sliding several time the blue lever. Maybe your charge corona unit is dirty with some dust or toner. Also power off and then on the printer. Check that everything is OK with paper path and tray.
P.S. DRUM UNIT has to be replaced after making a 20000 pages. If you don't want to buy a new one then it should be reset.
pifonski
Feb 19, 2011 | Brother HL 1440 Laser Printer
Brand new on power up attention light continually flashes and message says Please wait (Adding toner) and stays there forever
It is normal to do this "adding toner" operation aprox. 20 minutes. You have to wait until the printer enters in "ready" status. Take a little brake and relax, your printer needs to fill/refill the developer unit with toner dust from the cartridge.
Feb 16, 2011 | Kyocera FS2020D ECOSYS Monochrome Laser ...
Replacing cartridge, can't get past "please wait" message
I had exactly the same problem. Called Konica Minolta, and the best they could offer was 'Power down and then back up again". I did this but still had the same "please wait" that didn't go away. Then I powered down, unplugged the power cord, left a few minutes, then plugged in and powered up again. This time the printer went through a lengthy and noisy startup process, even printing out a status page. I then tried again, and this time immediately afte the "please wait" I got the "open door" as expected, and was able to replace the toner successfully.
I suspect though that you are right, and that the correct cartridge does get positioned automatically, and the "open door" message is not necessary. It would be nice if someone could confirm though.
Apr 10, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Trying to replace the empty black toner cartridge. I go through the steps to do this as outlined in the manaul. I get the screen that tells me "Please Wait." And I wait and wait and wait, and nothing...
Instead of following the directions as outlined in the manual, to have the printer turn the drum so I could extract the empty cartridge, I cut out a couple steps, by just reading the printers status display window. Followed the links that took me to where it said Replace Empty Toner Black, pressed the Menu Select button, and was given the OK to open the lid and door and replace the empty cartridge.
Sep 20, 2009 | Konica Minolta Magicolor 2530 DL Laser...
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Jun 29, 2009 | Sunpentown WA-1210E Air Conditioner
You seem to know this stuff
See the solution here.
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
May 22, 2008 | Motorola Mobility MD4260-2 Twin Cordless...
Motorola MD4260
I had the same problem.
Here is the solution that I received from Motorola tech support:
Done!
Nov 22, 2007 | Motorola Mobility MD4260-2 Twin Cordless...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
74 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
