Panasonic Lumix DMC-FZ7 Digital Camera Logo
D
Dave Harmes Posted on Feb 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use an 8gb memory card in this camera - Panasonic Lumix DMC-FZ7 Digital Camera
Tony Parsons
Level 3:
  • Panasonic Master 6,405 Answers
  • Posted on Feb 05, 2016
Tony Parsons
Panasonic Master
Level 3:
Answers
6405
Questions
Helped
1652195
Points
20272
Do neither the manual nor the manufacturer's site provide this information ?
Samsung s1030 digital camera keep showing memory full but have inserted new sdhc card how do i clear this as i cannot take any pics
Clear it by putting in a compatible memory card. The S1030 works with SD cards. Your 8GB SDHC card in not compatible. You need to use SD cards, 2GB and smaller.
I have a Jazz HDV180 digital camcorder and it takes a 8GB memory card. I put a 8GB HP memory card in and it says no card. I have formatted the memory card.
Try checking your manuel for specifically named memory card, sometimes certain cameras can only take certain memory card formats.
Hope this helps.
--- JD
To get the camera to play from 2gb to 8gb.at 2gb it will play about 40 mins.
its because you have the camera set to store the video in the internal memory not the SD card you have to change the settings so it will save into the SD card instead of the internal memory
1helpful
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
3helpful
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
Sony will not read 8gb Sandisk memory card. States, Reinsert memory card and flashes c:13:01
Check your owners manual...can your camera handle an 8gb card? Maybe all you need to do is format it in the camera.
Memory card error in 8GB card
Try to re-insert the card. If that doesn't help try to reformat it/delete all its contents. Also check in the manual what kinds of cards does the camera generally work with (although i doubt that is the problem).
8GB SD card not working in Fuji Camera
switch around the 8gb memory card
i had the same problem
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
