Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover Sping Vac
I have teh button for brushes turned to "on" and pull the trigger, but the brushes won't turn on.
  • 4 more comments
  • kymnewk1 Nov 18, 2007
    I am having the same problem with the brushes not spinning. I have cleaned the filter screen and the brush selector is on. I removed the brushes and re inserted them and still nothing
  • Kaime Nov 22, 2007
    I have the same problem with the brushes. They won't turn
  • Anonymous Dec 06, 2007
    same thing rhey wont spin help plz
  • deanhoover Dec 11, 2007
    me too. any solutions?
  • BossyVoss Dec 21, 2007
    I have the same problem, the brushes don't spin. I don't see how the brushes come out or what makes them spin to see what's not working. The answer here was no help.
  • ocpete Dec 31, 2007
    same problem brushes won't turn... How do I get to the ayr drive
    Welcome Back:
    Visited the website for 2 consecutive days.
Finally after at least 10 more attempts with the brushes and the lint screen and several words to make a sailor blush, The brushes started to spin again. Not sure what did it.
Posted on Nov 30, 2007
  • Kim Newcomb Nov 30, 2007
    After at least 10 more attempts re inserting the brushes and the lint screen ( several words that would makea sailor blush) The brushes finally started spinning. Not sure what did it.
How to remove brushes on a hoover f5887-900 steam vac
Take off both tanks, then turn the steam vac over. Using both hands, pull evenly on each end of the brush block. They will pull straight out. But usually it isn't necessary to remove the brushes. Usually the problem is a blocked screen.If you look at the vac from the front of it with it turned right side up, there is a little window. Pull that off and using your fingernail, clean off the lint. If your model doesn't have a window that you can access, look underneath, near the brushes for a red plastic frame, pull down and it will expose the screen. Hope this helps.
Aug 18, 2014 | Vacuums
Brushes won't spin anymore
There is a spring that goes on an arm, #32 in the picture. It actuates the turbine so the brushes will turn when the handle is tilted back, and stopped when upright. This might be where that spring goes. You may have to take the top cover off to put in on. After you get it on, and the brushes still don't turn, look up in the square hole where the shaft on the brush block goes into, turn the unit on and see if it is turning, if not then the turbine either needs to be taken apart and cleaned or replaced. The turbine is what drives the brushes.
Mar 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
I have a Hoover F5914-900 Steam Vac. I have used the upholstery/stair tool in the past with success. Today I installed the accessory tool , but when I turned the machine on, the fluid drained out the...
If fluid drains out through the bottom of the machine, rather than through the brushes, you most likely have a leak in the quick disconnect valve. ( part # 43523004, msrp $4.99 ) This is the small valve that the end of the hose connector snaps on to. If this is the problem, it will also leak when doing normal rug shampooing. This is a somewhat common problem with this machine. The valve will need replacement.
Jun 18, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
Confirm that the hose is correctly connected to the clean water supply. If so, then remove it and, with the trigger operated on the hose, try to blow into the water feed connector. If you cannot pass air, the feed tube in the hose is clogged and must be cleaned (either by running faucet water into the brush end (with trigger pulled) or by using compressed air....
Nov 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Hoover turbo vac 5200
Pull out the brush block, do the brushes turn freely and is the shaft that goes uo into the turbine there or did it break off. If the brush block is ok, then the turbine is probably bad and will need to be replaced.
Dec 12, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
120 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
