Question about Sony KV-27S42 27" TV
Lost remote control
Need help! During my move, a TV remote control was lost. Tried to get an access to "Menu" option using the Universal Remote Control to tune the TV - no sucsess! URC is only for power, channels and volume. Could somebody give me an idea of how to get into the "Menu" option without the remote, or where to get one. Thanks a lot.
Re: Lost remote control
I have been there with my KV-27S42 and lost the remote. I bought one from Replacement, it doesn't look exactly like the other one (a couple years ago the replacement DID look like the Sony and they must have been threatened) so now it looks a little different but is an equivalet and will solve your problem for $18.
Here's the link:
Now my trouble is my KV-27S42 quit working YESTERDAY and I think it's going to cost more than it's worth. May have to abandon Sony because I read about a lot of failures.
Posted on Nov 22, 2007
0 characters
3 Points
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
Apr 08, 2012 | Standard (CRT) Televisions
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
Apr 06, 2012 | Panasonic CT-36D32 36" TV
I have a 19'' older (approx 1999) Sharp tube TV that won't show the cable channels even though the cable is hooked up to the tv (the cable has been tested with another TV and works perfectly). There is no...
Even with the TV in the wrong mode, you should be able to see some channels lower than 12. Try that first and report here what you see. If you can get a few in that range (2-12) but nothing else, then the TV is in broadcast mode not cable. You will need to change it to cable mode to get the remaining channels. You should be able to locate a universal remote for $5 or so that will allow you to get into the menus.
Jun 18, 2009 | Sharp Standard (CRT) Televisions
Do i need the original remote control?
yes a new remote is needed if the option of a panel menu is not there.on yyour tv get the model number and make order from manufacture
May 14, 2009 | Orion1934 19" TV
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Apr 28, 2009 | Hitachi C21 F800S TV
General electric Universal remote control codes
i lost my code book for my ge remote control
Apr 11, 2008 | Broksonic CTVG-5463GVC 19" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from:
Mar 16, 2008 | Toshiba 24AF45 24" TV
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
I have this problem as well..have tried many universal remotes..still cant access menu options
Dec 02, 2007 | Sanyo DS31520 31" TV
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Sony KV-27S42 27" TV Logo
137 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
