Question about Black & Decker Tools & Hardware - Others
Broken drive belt on belt sander
Need to find a drive belt for my model BR400 Type 1 belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
  • Ed Dupnick
    Ed Dupnick Sep 16, 2014
    The noted belt part number A 6R 3-060031 has been changed to A 6B 3-060031 but otherwise the informmation and specs provided are corrent. Thanks to this individual who did the detective work and shared with all.
Replace timming belt For chicago belt sander
Posted on Jan 04, 2011
I have a used BR400 Type 1 with a bad bearing. I will send you my belt. E-Mail me @ borchertdist@gmail.com
Posted on Nov 28, 2009
  • 2,176 Answers
I just checked both types listed and they indicate that these belts are no longer available and you would need to contact the service center. Let me know and I might be able to go another route to find one.
Posted on Jul 15, 2009
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
I want to replace a broken drive belt for the Br300 Type 1 but am having problems. Please advise as to proceedure for replacing this belt. Thanks in advance for your help.
Look between the rollers that the sandpaper belt travel on. You will find a lever which can be released. Once you release it, you can pull the old belt off and slip the new belt on. Place the release lever back the way it was and you are done.
Apr 15, 2011 | Black & Decker BR300 3''x18'' Belt Sander
I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
May 25, 2010 | Campbell Hausfeld Tools & Hardware -...
My DS321 belt sander had the large drive roller(and belt)came off on the first extended use. Looking at an IPB no thrust washers were found either.
I would recommend going to Dewaltservicenet.com and typing in your model number and on the next page find the type number for the tool. I took a guess and found 2 thrust washers for the DS321. Let me know if you need more assistance and I will try and help
Jul 20, 2009 | Black & Decker 3 x 21 In. Dragster Belt...
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Need belt for black and decker sander 110 xl 031
The belt from Jason 110XL031 is Identical in size and apperance.
Jan 07, 2009 | Black & Decker BR300 3''x18'' Belt Sander
BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Nov 14, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
1,416 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
