Question about Cell Phones
I dont have any sound during phone calls. The ringer and all other functions including text messaging work. They other party cannot hear me and I cannot hear them during a call.
Blu Advance 5.0 ringer sounds won't work.
Hi if u have silent mode turned on u won't hear a sample ring tone check where u adjust volumes there should b a silent mode on or off..Cheers..
Dec 20, 2016 | Blu Cell Phones
Hi! i just bought a lg-ks360 and i don't know what to do! i just can't hear the phone ring when i get a call or a text message. i tried using the alarm clock and it was useless, i just didn't hear it ring!...
You may just have the phone's ringer at a very low volume or on vibrate. Just raise the ringer volume and you'll be able to hear everything. If you're listening to a mp3, pause it and try to raise the ringer volume.
Apr 30, 2011 | Cell Phones
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
I can't hear any sound.And instead of ringing it vibrate.Even I've try to listen song but nothing is happening.
Hi there
First go to your ringer settings to check if the volume is not too low or turned off.
The problem is from your RINGER/SPEAKER,
The ringer/speaker is what brings out sound from your mobile phone when you are called,you receive a text message or you are playing music.
The ringer of your phone is faulty and you need to get a repairer to replace it for you to solve this problem
Thank you for visiting fixya
Feb 25, 2010 | Sony Ericsson K800i Cellular Phone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
How to stop the noice after sending txt
If you have a sound settings option on your phone. You should be able to go to Ringer type. Which should list message, roam ringer & voice call. Select messages and then text message. My sounds, and then select no ring, and now you should have no sound when texting. Let me know if this helps
Jun 14, 2009 | Samsung J700 Cellular Phone
Sound?
Make sure you have a ringtone assigned for your texts.
Settings<sound settings< alerts < text message< choose the sound you want to hear. hope it helps :)
Mar 19, 2009 | Motorola Mobility W315 Cellular Phone
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
97 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
