Question about Frigidaire Dishwashers
Frigidaire Dishwasher won't start (lights cycle but no water/motor) Model Number: FDB1050REB2 Brand: Frigidaire Our dishwasher is 1.25 years old and already not working (grrr!). When it is turned on, the lights cycle through like a normal wash cycle, but the motor isn't engaged nor does any water cycle through. This happened about a month ago and I took everything apart to make sure all of the connections were secure and it started working again...not this time. Any ideas?
  • rhamilton210 Nov 23, 2009
    We have a dishwasher Model FDR252RBB1. It has power to it but is completely dead. Is there a lock out switch that I can replace or a reset button somewhere? If the heater element goes out, will this cause this problem?
    Thanks
SOURCE: Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Posted on Aug 14, 2007
SOURCE: dishwasher not draining completely
If you take the toe panels off and look at the motor you will see the discharge anti-siphon tube there with the drain hose attached. That tube is the discharge major restriction point. Be careful not to destroy the anti-siphon valve, by pulling the bale, remove it, a flapper valve. If you can't see through the tube you have found the problem. Punch a screwdriver into it to dislodge the crap and clean it up. Put the anti-siphon valve back in as found and check it out. Be careful, when you remove the tube , water will come out of the pump assembly. If you remove the hose be sure to watch for water there also.
Posted on Jan 12, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Posted on Nov 23, 2008
futureloginn
  • 734 Answers
SOURCE: Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Posted on Dec 10, 2008
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
Hi, I have a Frigidaire dishwasher, it has stopped working, when I put it on normal mode the "washing" light flashes but the machine does not start. Can anyone give some advice on how to fix? thanks,
Hello FJ, thank you for your inquiry!
I understand that your Frigidaire dishwasher is not working and all it does is flash the "washing" light. It sounds like a possible problem with your keypad or control panel. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you from purchasing unnecessary parts. -Matt
Jun 08, 2015 | Frigidaire Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
Frigidaire dishwasher has no power and won't start
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 17, 2012 | Electrolux Fridigaire Lp Conversion Kit...
Model #EDW5500DSS1
Oct 16, 2012 | Electrolux Frigidaire Professional Series...
Model gu1200xtlq dishwasher can't find my manual it is 8 years old and having problems with dishes not getting clean particles left inside cups and on dishes and even inside the tub after a cycle
you can go to www.frigidaire.com and input your model number in the manuels colum and you will be able to download a new manuel.
to clean you dishwasher you can use some CLR or any other kind of lime and scale remover to clean the inside and the spray arms.
if this does no good then you may need to replace the main wash motor.make sure there is enough water in the unit when it is running lack of water is a big problem with not getting dishes clean
Jul 05, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Wash Cycle Not Working
Either the wash motor plug is loose or the motor itself is bad.
Dec 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher problem - no water in the tub
hi.
The sensore key that control the door of dish washer may be show that the door is open & it doesent let that water come to machine . you should checke the key
Nov 09, 2008 | Frigidaire 24 in. FDB1250RE Built-in...
Frigidaire 24" FDB1050REB2 Dishwasher It will not allow water to come in. The pump works, the motor runs, but it will not fill up. Water valve has been replaced. Pleas help!!
Friend,
ngfam1 At your service!
You plain old need service ! I am not hands on from this side of the wire!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New applinces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 31, 2008 | Frigidaire Dishwashers
Dishwashers Logo
268 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
