Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
Zoom stuck, and loose ring of plastic in the lens... help
    Brigadier General:
  • 3,006 Answers
Your lens is totally beyond economic repair, sorry. I've looked into repairing the same fault on this lens before. It's only the basic kit lens as supplied with the camera so it was built with low cost as an overriding primary concern and no real thought for future repairs or spares availability.
The good news is that there are normally a fair number of these lenses both used and brand new at relatively low prices. many owners sell the kit version to upgrade to a better lens and many retailers often have new unboxed (usually ex-display) kit lenses for around 30% less than the new and boxed versions.
Posted on Jul 19, 2009
Nikon lens 35-70 af zoom ring stuck
This is not a do-it-yourself type of repair. If you try to do any disassembly of the lens yourself, you will end up with a table full of parts you will not be able to properly reassemble and it will cost twice as much to have it fixed. Send the lens to Nikon or a professional camera repair man.
Feb 09, 2014 | Nikon Cameras
Hi, can tell to me why my 18-200 af vr lenss go
The "problem" is that the lens has a zoom creep issue. If you are the original purchaser, and the lens is under 5 years old, you may want to contact Nikon repair facilites in Melville or El Segundo to have it checked out.
Some users on forums have claimed that Nikon fixed the plastics ring that contribute to the zoom creep. Apparently, using a rubber band around the zoom ring will minimize the problem.
Hope this helps,
Andrew
May 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
Nikkor 18-200 mm VR with loose front ring and stuck zoom barrel
Unfortunately not. If the Nikon centre think it's been dropped, then you're stuck. They may well think so due to additional wear and damage caused as the initial fault progressed; this may well resemble the damage caused when a lens is dropped. You should really have sent it for repair as soon as the fault occurred.
All you can do is to write a letter of complaint to Nikon, asking them to intervene on your behalf with their authorised repair centre. It will help if you tell them how long you've been loyal to Nikon for and what other Nikon products you own; also state that if you must buy another lens that your money will instead go to one of their competitors instead and that when you replace your camera you will think hard before purchasing from Nikon again. It also helps if you tell them that you were well aware that you would be charged for any repairs caused by misuse, such as dropping your lens, and so would not have bothered to try and claim under warranty under such circumstances as it wasn't worth the risk of having to pay a big bill just to get a broken lens returned to you. Tell them that you have not dropped the lens and so you dispute their findings, and at the very least request that the lens is returned to you without charge so that you can get the lens examined by an independent repairer.
As long as your letter is polite, factual and states your argument clearly then you maximise your chances of getting them to revise their position to give you the benefit of any doubt.
Good luck.
Mar 09, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Dec 13, 2008 | Canon EF 24-70mm f/2.8L USM Lens
Hi my lens is stuck in the out position and zoom error is on the screen can you help finepix f40fd
Lens needs to be removed, carefully stripped and re-assembled. If the three small plastic guide luggs on the inside slide ring are broken sell for spares. Very hard to repair.
Dec 01, 2008 | Fuji FinePix F40fd Digital Camera
Zoom ring is loose and drops/slides on its own
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight. When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want. Hope this helps. Jay
Oct 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
17-85MM IS - mechanically stuck at 17mm - will not zoom -
Hi all,
I've had the same problem. So I decided to give it a try because I didn't find any solutions on the net. Unfortunately you have to pay pretty much for a Canon lens while the internal quality is pretty cheap, the whole mechanism is of plastic and this is also the problem. And after a while some screws will vibrate loose from the plastic components and canon could have done this better.
Probably within your lens is now one of the three zoom mechanism screws complete removed and you will notice that there is some abnormal movement in the zoom part. Unfortunately these screws are deeply mounted inside the lens and you need a lots of skill and patience to get it fixed.
First you need to completely disassemble the lens, and please make a picture of your lens after every step you make because I had to disassemble my lens 4 times! Because some of the elements was not right in place.
I will try to place a more complete description later today including some pictures.
Regards Gert
Aug 30, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
315 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
