Question about Dell A215 Computer Speakers
Speakers and controls are working but sound barely comes out.
Volume control on speaker and computer are on all high even and just whispering sounds from speaker coming through
  • jk_10_79 May 11, 2010
    What are you trying to listen to and what program is running it? If you're trying to play a mp3 or music file, check to make sure the volume on the program that runs it is not set low (media player/winamp/etc). Have the speakers worked in the past or did this just suddenly happen?
  • 22 Answers
Check the back of the computer. Typically this caused when the connection is loose or the speakers are plugged in to the wrong jack. The correct jack on a Dell is usually a light green color. The Microphone is pink, etc.
Posted on Jul 15, 2009
Subwoofer repair
Check your connections. Make sure everything is plugged in properly. If it is still making a sound, even a whisper, then the amp is probably fine. Do you have other speakers connected to the amp? If so, they should be sounding too. If not, then it's definitely an amp problem. Ebay sells tons of .... well, everything, so you should check that out...
Mar 05, 2014 | Jmlab Audio Players & Recorders
Low sound from speakers
either bad quality of preamp or the speakersistem has some probblems
Apr 22, 2012 | Cyber Acoustics CA-3080 Computer Speakers
My computer volume control to at the max but the sound is but a whisper
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 13, 2011 | Audio Players & Recorders
My laptop's audio has stopped working, and the audio area says that the speaker is working and the sound is on, but nothing plays, not even the test tone. I think it is a driver issue. The speakers are...
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
or
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 11, 2010 | Computers & Internet
The volume of my speaker is so low, i cant barely hear it, i cant see anything wrong with it, i checked the AC in, i checked the jack for any short circuit still iget a very low volume out of the speaker...
look on the lower right corner of your screen. there should be a volume icon down there. it looks like a speaker. click that and see if it is set up or down low. if it is low turn it up then it should work. this controls the amount of sound coming out of the sound card on your computer.
Jun 27, 2010 | Creative Labs : Creative Inspire 2900 2.1...
Hello, My speakers work but very little sound come out. The speaker with the volume control works and the other one does not. The volume control speaker gives sound but barely any. All volume buttons on...
Sounds like the amp in the speakers has a problem. First thing to do is try the speakers on another PC, or an MP3 player etc. If the speakers work for this then they're OK.
If they don't work for this (more likely) you should buy a new set of speakers, considering the small cost of replacement.
Jun 17, 2010 | HP (KK912AA) Speakers
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Speaker volume on one side extremely low
i have the same speakers.
but isntead of one side going,
both sides are dead.
and the light on the control side doesnt even turn on
it is plugged in
but i do not know what is wrong
solutions please?
darkhunter234@hotmail.com
Jan 24, 2008 | Dell A425 Computer Speakers
Dell A215 Computer Speakers Logo
316 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
