Question about ASUS Eee PC 900 Notebook
Won't Boot Computer powers up all lights on ever wifi but the screen only shows lines like burberry sometime plaid looking. I even tried a external monitor only difference monitor shows asus on booting then goes black. is there a way i can reload this unit software?
Unmountable boot volumn error with lines on screen
this may help. just watch the video and folow the directions. good luck.
Apr 11, 2013 | Dell Inspiron 8600 Notebook
Dell xp will not boot and has lines across the screen
I would say your Graphics Adapter is gone. Have you removed the HDD and tested it? Has it been Cleaned? Fan? vents? Heatsink? Overheating? If the graphics adapter is gone it's a death sentence in a laptop. You can try replacing the Thermal Paste and cleaning the Laptop out. But it may be to late.
Apr 11, 2013 | Computers & Internet
My battery light keeps coming on and it says service charging system. Had my battery and alternator checked they say there good.
After waiting for a few days, [url=http://www.burberrymarketing.com]burberry saat[/url] it becomes worse and eventually fail. I also do not quite know how to proceed. Even engaged in the the Timex company or Amazon? Well, the the Timex company network when very friendly, I went back to it, oh.You decided to be more careful, I read all [url=http://www.topburberry.com]burberry watch sport[/url] previous reviews of this particular watch. Table I is a function, you need to actively triathlon training, sports. Everything is perfect work for three weeks, then today is cloudy lens ...I am looking for a good casual watch, I [url=http://www.burberrychronograph.com]burberry watch for men[/url] wear too gorgeous. I also watch "destruction". I combined the actual plastic tape applied to the visible region, and a little luster. 25 U.S. dollars, the exchange rate of the tragedy.Readability: Watch INDIGLO light, mirror [url=http://www.burberrychronograph.com]burberry men watches[/url] designer watches indicators, and therefore capture almost all of the light, you do not need them, except in darkness, use it. Move the focus to the front of the light or dark ambient light, clearly show that the bright light.I can not say, In short, you are almost blind, and this is a good thing, you can not look at the under all lighting conditions, [url=http://www.burberrsaatsale.com]burberry watches for men[/url] see I wear a lot of watches.burberrywatches .... ...
and [url=http://www.burberrymarketing.com]burberry watch women[/url] request a new watch replacement products launched four days, Amazon because it provides a very simple return address labels, I stood in my soul, I did not do anything thing. Alternatives to get to watch, to see a drop-down box, I used the same packaging, a failure.
Even if there is no trouble to make a fuss.Comfort: I looked at the general, tend to [url=http://www.burberrsaatsale.com]watch burberry men[/url] have an influence on my wrist. I have no problem, rather than see it! Lightweight with plastic and I could not sleep.The look and sound: I, I looked at it. [url=http://www.topburberry.com]burberry sport watch[/url] Wherever you go sleep in pillow.Time, you ticking sound is low, it becomes a problem:See a few weeks, I did not waste his time. I want to, I want to practice, I'm in the review, not to mention it's appearance.
Jan 05, 2013 | Cars & Trucks
Computer won't boot up
Does it sound like the computer booted up except the screen is black. Do you hear fans running, the hard drive spinning? Maybe the system booted up, but the screen has an issue.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 15, 2012 | Computers & Internet
My HP G60-230US Computer will not start. The computer is a little more than 2 years old. Every so often when I would start the computer it would say "No boot device found". I would restart the...
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
Feb 28, 2017 | HP G60-230US Notebook
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Screen has no image except it looks like madras
Try to plug in this monitor to another pc. If it still does not show an image you may have to replace the monitor.
Mar 15, 2010 | HP L2208W Monitor
My Compaq Presario F732NR Laptop w/Vista won't Boot.
You have done an excellent job of diagnosing a MotherBoard fault. This is undoubtably the problem. Have you removed all/any cards attached too, like say the WiFi?
Feb 08, 2010 | Computers & Internet
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
ASUS Eee PC 900 Notebook Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
