Question about Nikon Coolpix S1 Digital Camera
When the camera is on the screen is blank/black as if shutter is closed (it is not). i've tried changing the settings but that didn't help. any ideas what the problem could be?
    President:
  • 1,223 Answers
CCD FAILURE !
Just Call Nikon they will do it FREE OF CHARGE ! ask them about BAD CCD !
it is a known manufac fault and all are doing it FREE !
Pls rate me WELL
Posted on Jul 16, 2009
  • Jonat1 Aug 12, 2011
    Interesting...I just called Nikon service, I also have the black screen problem with Coolpix S1. I didn't mention CCD Failure, as I didn't see this post until now. She, the service rep told me that they have not received even one complaint on black screen issue with this camera. If I want them to repair it, send it in and it will cost anywhere between $87 and $117 !!
5 Suggested Answers
SOURCE: Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
Posted on Nov 22, 2006
SOURCE: Shutter won't close on Nikon D70s
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
Posted on Jun 11, 2007
  • 59 Answers
SOURCE: Shutter won't open/close, and blank screen on "capture."
It prolly took a bump at some point or has crud inside...try cleaning it GENTLY with alcohol NOT WATER.
Posted on Aug 27, 2007
t00nz
  • 4738 Answers
SOURCE: I have a Cannon PowerShot
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jun 06, 2011
My Canon SD1000 screen has gone blank.
First press the DISP button to make sure that you didn't just accidentally turn it off. Next, a stuck shutter is another common failure mode for digital cameras (very common for the SD1000 by the way, but also very easy to fix). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 16, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
Jun 06, 2011 | Canon Cameras
Black screen
First try pressing the DISP or DISPLAY button. If that didn't work, have you tried downloading the photos, and are they also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Finally if the photos are fine, and it's just that the screen is black, then it's likely just a loose ribbon cable connector to the screen. In that case, you would need to opne up the camera to reseat the cable.
Mar 15, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Black lcd screen
First press the DISP or DISPLAY button to make sure that you just didn't accidentally turn off the screen. Next, have you downloaded the pictures it takes, and are they also black? If so, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 12, 2011 | Canon PowerShot A620 Digital Camera
My display screen is black when I go in camera mode, how can I resolve that problem
First try pressing the DISP or DISPLAY button to verify that you didn't accidentally turn it off. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 07, 2010 | Canon PowerShot SD1000 Digital Camera
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
LCD screen is blank and pictures are also blank
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
My cannon s21s has a blank screen
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 20, 2009 | Canon Cameras
Black Screen and takes blank pictures
It sounds like a stuck shutter. As the camera is less than a year old, Nikon should fix this for you for free under warranty. Contact them.
For others that experience this with cameras that are out of warranty:
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 27, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S1 Digital Camera Logo
309 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
