I have changed the batteries, taken out the SD card and then put it back in, and plugged it in to my computer/laptop. It will not turn on!
SOURCE: 2 gig sd card problem
I found a user manual online says max memory is 256mb on this camera. Wont recognize anything bigger.
Here's the manual in pdf
http://www.theusermanualsite.com/mdownloads/3d5c169f-850c-2724-ed2c-2d458174b40a.pdf
SOURCE: i bought a new sd card and when i put the card in
try formatting the card in your PC
Most camera Mfr's do not recommend this but I have found it to work.
If you have an adaptor that will allow you to plug the card into your pc just do so and format whatever drive letter it assigns
SOURCE: new sd card says full
Check and make sure the SD card is in all the way, it should make a clicking sound when it's in all the way. I had this same problem with my Vivicam 8025. Hope this helps!
Testimonial: "you are right, thank you so much!"
SOURCE: I cannot take any pictures, beacause the camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting tips for this problem may be found at this link. The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include having the tiny slide switch on the side of the card in the wrong position, or problems the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card).
