Question about Microsoft Computers & Internet
Hi! I am using a compaq presario 2500 laptop! My onboard keys are not functional ,so I have . purchased an ext. keyboard! there are no functional key on this keyboard. Can u help me as to how to adjust the brightness of the screeen of my laptop?
    President:
  • 627 Answers
XP: right click on desktop - properties
click on screen saver tab and click on power button
VISTA
Go to control panel, adjust used mobility settings, then adjust screen brighness
Posted on Jul 16, 2009
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
Compaq 730us touch pad not responding
Hi
To fix an unresponsive touchpad on your laptop/desktop XP Home, XPPro:
Reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 06, 2011 | HP Compaq Presario 730US Notebook
Compaq Presario CQ60-211DX keyboard not working
open the laptop and bring out the keyboard .
whash it with Alkohol and after 20 minuts dry it
and after 3 hours install it and test.
if dosent solved i have it .i can send u
Jun 09, 2009 | Compaq Presario CQ60-212US Notebook
Compaq Presario 2500 (2598us) loose keyboard
You might want to check the keyboard connection. It sounds as if it's not connected or seated properly.
Aug 20, 2008 | Compaq Presario 2598Us Notebook
Compaq laptop keyboard mulfunction
try having your laptop checked by a competent technician... there might be an obstruction in your keyboard (like dust) which causes the key to stuck and have it cleaned
Aug 09, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Product Key
You should got a reinstallation CD with your purchase.
Try looking on the back of the laptop.
May 02, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Replace keyboard, now computer will not power up
you could have the keyboard plug in backward it is the onboard key pad you are talking about. also if you purchased the wrong one it will not work . and the laptop will not operate.
Dec 07, 2007 | Compaq Presario 700 470024-192 Notebook
Keyboard problems
Keyboard is shot. They do that due to the heat laptops generate. I've probably replaced 200 laptop keyboards in the past 5 years. You can buy one on ebay for about $21.00. http://cgi.ebay.com/NEW-HP-COMPAQ-Presario-2100-2500-Keyboard-317443-001_W0QQitemZ190124162270QQihZ009QQcategoryZ116289QQcmdZViewItem Ray
Jun 20, 2007 | Compaq Keyboard
Computers & Internet Logo
126 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
