Toshiba Regza 46X3500: part number for power supply board?
  • Jim Krause May 11, 2010
    The Model number does not jive, please check it and re-post.
5 Suggested Answers
  • 10 Answers
SOURCE: toshiba regza lcd 46x3500
This is what is known as a dead pixel. If you have a standard wide screen lcd monitor it has over 1 million pixels. It is not super un-common for one to go bad. It will either always be dark or in your case always be lit. It is not worth it to repair, and in most cases unless you have multiple dead pixels with in a square inch of screen, it is not covered under warranty either.
Each pixel is individual and the problem will most likely not spread.
Posted on Jul 08, 2008
  • 668 Answers
SOURCE: toshiba regza 46rv530u will not turn on
Check the ac fuse. In a couple of cases because of a power surge the fuse opens up.
After replacing, the sets have worked normally.
Posted on Jun 17, 2009
budmrtn
  • 11361 Answers
SOURCE: no pic and no sound on toshiba regza was told the
$99 for the replacement if that is for sure the problem.
http://cgi.ebay.com/Toshiba-42RV530U-Power-Supply-PE0546-V28A000718A1-A221_W0QQitemZ360118685211QQcmdZViewItemQQptZTelevisions?hash=item53d8bf0e1b
Posted on Nov 04, 2009
welcomejee
  • 10594 Answers
SOURCE: Toshiba Regza 42RV535U 42 in.
TV needs back light inverter board replacement as discussed in chat session, required board is available with shopjimmy.com
Thanks.
Posted on Jan 25, 2011
TV worked 1 day and no sign of power when turned on the next.Toshiba REGZA 42
if no any power indicator at the front panel, check for a blown fuse at the power supply board.
Oct 27, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Power supply from My Toshiba 32A3000P is defect. The voltages and currents are not provided so therefore the TV is notswitching on. I need the P/N of power supply in order to buy it. Can you support me?
Hi
To buy a new power switching regulator board, you needn't have the part number of it. It can be purchased from Toshiba Authorised Service center by informing the exact model number of your Toshiba TV. They will give you the orginal replacement board. The identification number will be printed on the circut board itsef. You can also buy it from "Alibaba" or "Ebay" by quating that PCB number. Get into their web sites and search for your board. They will send it to you by E-payment. OK.
Jul 15, 2011 | Toshiba REGZA 32A3000P 32 in. LCD TV
Hello, I have an Toshiba REGZA 42" LCD TV, the
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
Jun 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a 42 inch Toshiba Regza and when I try to turn on the tv all that happens is the power light blinks three times x 3 then stops. Is this a faulty power board or signal card/board. need part numbers
This problems alway power supply board are the problems 90-95% of the times.Take the tv aparts.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 10, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My toshiba regza model 32wl68p is difficult to turn on from standby.Ihave to unplug in and retry numerous times before it turns on
Please replace bad capacitors in power supply board or replace complete power supply board available HERE to solve tv problem.
Thanks.
Jun 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Where do i get toshiba powersupply for the monitor? i use Toshiba REgza 32"
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Nov 20, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
32'' Toshiba Regza difficuut to switch on from plug & standby
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 22, 2017 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
The picture on my 42 inch lcd toshiba regza has gone out on all inputs but the sound still works
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No pic and no sound on toshiba regza was told the power board was out is this an expensive fix
The 42RV530U is known to develop problems in both the power board and the main board.
You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Nov 04, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
