Question about NEPTUNE/ELKAY AG2522 STANDARD SERIES SINGLE BOWL SINK
How do the clips go on 3/4 granite 3/4 plywood
  • 62 Answers
You might have to route out the wood where you want to put the clips because the clip hardware is not intended for a top thickness greater than about 3/4 inch
Posted on Jul 16, 2009
How do you attach the clips for a double sink composite granite sink
if what your speaking of is a sink that's made from 5 pieces of granite , id not suggest you try to use clips to hold it on the bottom of counter top , id suggest you either use Hot glue (works fast) or epoxy (2 PART) either of these would keep you from stesssin the material and it wont snap on you a bucket with shims can be used temp to set it all on (weight ) till epoxy dries
Jan 03, 2017 | Home
Need instructions for granite sink oc3322-1, cut-out already done for counter top, ready to put in
There should be a clip kit with the sink if not contact moen you should already have this its part of the deal
Dec 14, 2010 | Moen 25425___ Stone Granite Double Bowl...
Need to stabilize machine and have granite countertops
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Nov 20, 2010 | Siemens 24 in. SL84A305UC Built-in...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Just did a kitchen remodel, kept the Bosch dishwasher model SHU9955UC, contractor having problems will attaching dishwasher to granite. Any suggestions? Thanks!
Sep 24, 2010 | Bosch SHU9955UC Built-in Dishwasher
I cant figure out how to use the clips for a Franke topmount granite sink. No instructions came with the sink. It is a formica countertop.
We can't figure it out either! It seemed to come with undermount pieces (its not an undermount sink) and some blurry IKEA-style instructions. Been working on this 3 hours!
Anybody...???
Aug 04, 2010 | Franke Home
I have granite countertops< so i have to install the clips on the sides of the dishwasher instead of on top. however the dishwasher has no holes with plugs
If you can't find any place on the sides to mount the clips then you can take a piece of wood that matches your cabinets and fasten it to the opening in you cabinet for the dishwasher so you will have somethink to mount the washer to. Make sure your washer is level so you can figure out the gap size at the top, then pull the washer out and mount the wood to the cabinet. You could call the guys who installed the counter tops and see what they would or could do, but I wouldn't drill into the granite myself
Jan 07, 2010 | Dishwashers
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Need side mount brackets gpf65 because of granite counter top, model #ghda485n10cs ser# rm763786b, quietpower3 dishwasher
I don’t know your counter situation, usually you have to put dishwasher in a bottom cabinet and mount both side. Suppose you only have one side to mount, you have to go to home depot to buy a 90 degree metal mounting bar, mount the top part to your top granite support board, the bottom side mount to the dishwasher, it should be a ¾” plywood board underneath the granite, you can use ½” screw to mount it.
Hope this can help you,
Jun 25, 2008 | GE Dishwashers
NEPTUNE/ELKAY AG2522 STANDARD SERIES SINGLE BOWL SINK Logo
117 people viewed this question
Top Neptune Home Experts
JonSnell Electronic
JonSnell Electronic
Steve Waclo
Steve Waclo
Are you a Neptune Home Expert? Answer questions, earn points and help others
