Question about Canon imageCLASS D880 All-In-One Laser Printer
My Canon Imageclass D880 is printing extra lines across the paper every 3 3/4". I have cleaned several times and changed toner cartridge, any suggestions?
  • Claudio Nelli May 11, 2010
    have you changed the drum?
All Office
  • 58 Answers
SOURCE: Canon Imageclass D880 all-in-one
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
Posted on Jul 29, 2007
SOURCE: Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
Posted on Mar 25, 2009
sitehr
  • 94 Answers
SOURCE: D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Posted on Jul 22, 2009
cene765
  • 787 Answers
SOURCE: canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Posted on Oct 05, 2009
  • 56 Answers
SOURCE: Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Posted on Oct 22, 2009
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
Canon ImageClass D660
printhead needs to be cleaned and so does the black roller that the paper is printed onto.
Jul 24, 2008 | Canon imageCLASS D660 All-In-One Laser...
Half of the paper is black and the other a normal
Problems in the scanning
You tried to print something?
Scanner Flat Cable fault requires replacement.
Part number HH2-3222-000
Sep 21, 2009 | Canon imageCLASS D320 Digital Copier
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Getting LCD Error: Toner not set Insert Toner
Sometimes what causes the problem is the black cartridge guide on the inside rear of the machine. It comes loose and so when you put your cartridge in it does not line up with the contacts properly. The parts cannot be ordered seperately. It comes with the whole rear assembly. The part # for it is HM1-0244
Feb 14, 2009 | Canon imageCLASS D320 Digital Copier
Can't replace cartridge in Canon ImageClass D880
Something is blocking the access, or the clips may be bent or broken
Dec 24, 2008 | Canon imageCLASS D880 All-In-One Laser...
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Will not receive faxes
This is a safety feature. If it tried to print the fax, but there was no toner, not only would you not be able to read the fax, but it would be gone forever (it gets erased from memory once it is printed).
Mar 12, 2008 | Canon imageCLASS D880 All-In-One Laser...
Blank pages printing on ImageClass D680
Greeting IceCreamMan, It sounds like you?ve eliminated the toner cartridge as the culprit. I suspect that when you did the disassembly and connector was missed or an electrical connection fault developed. Look for the electrical contacts that connect to the toner cartridge, they may not be making contact. Make sure the spring contacts on the printer are connecting to the cartridge and that they are clean. If that?s not it then check: -all connectors to make sure they are plugged in and oriented correctly -for missing or incorrectly aligned top or side panels (sometimes they are linked to switches) -all wires (for damage) and secure connections Let us know how it goes and don?t forget to rate the posting.
Jan 04, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
old marine
old marine
