Question about Xerox Office Equipment & Supplies
WE just had the copier serviced and now it won't start up. you can hear the motor click but the control buttons don't light up.
    President:
  • 1,185 Answers
Call the Xerox man back , they must give a warranty of so many days after a repair
Before you do open and close all of the panels because what you can hear is the safety relay
It may just be that a door is not closed properly
Posted on Jul 15, 2009
Fazer won't start and I don't know why
Hi, Brevante and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
07 FZ6 won start help
Bike will not start
http://fz6.uw.hu/service/2004-Service-LIT-11616-17-50.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2008/lit-11626-21-60_fz6_1458.pdf
May 06, 2013 | 2007 Yamaha FZ6 Fazer
Bmw gs 1200r adventure won't start with a new battery
Does the motor turn over when you hit the start button?
If you just hear a Click, click, click without the motor turning over, then your battery voltage is low and will need to be charged.
If your motor actually swings but doesn't fire up, chances are good that it is the fuel pump regulator that had blown. R1200GS 08 09 K25
Part number 16 14 7 720 776 is what you will need.
Mar 05, 2013 | 2010 BMW R 1200 GS Adventure
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
1991 toyota camry turns over but wont start
i have a 91 camry Dx the radio and lights come on but the car won't start up i don't hear any clicking sound when i try to start the car up
Apr 23, 2012 | 1991 Toyota Camry
Dryer won't start
Obvious stuff: Check main power source. Is the dryer plugged in? Do other electrical things work when plugged in to the outlet? If not, check fuses or circuit breakers. If good, is the timer/cycle control out of the "Off" position? Try several different settings.
Door check: Is the door safety switch closing? If it is or if you don't know if it is, and if you can get to the switch, you can take the wires off the switch and connect them together with a jumper wire ( unplug the machine before you do this!). With the wires clear of any metal, plug the machine back in, then press the start switch (you can leave the door open). If the machine starts, the door switch is defective.
Sound check: Do you hear a motor running when you press the Start button? Listen carefully; electric motors are very quiet. If the motor is running, your drum belt is probably broken or has come off the idler pulley. If you can take the front (sometimes the back) off the machine, this is an easy fix. Just put the belt back on the pulleys and around the tumbler drum, Note: there is a reason the belt came off if it's not broken. Look for loose or damaged pulleys or springs, including on the motor.
Do you hear a hum without the motor running? If so it indicates wearing of the motor bearings, brushes or the stator. Brushes can usually be replaced easily, but other motor problems require professional repair or replacement.
Smell check: Any unusual odors when you try to start the machine? A hot rubber smell means belt trouble. Check the belt as above. An electrical burning smell means motor or other electrical failure. Call a repair man unless you know what you are doing.
Electrical check: If you can read an electrical schematic (usually on a sticker inside the dryer cabinet or in the owner's manual) and you can use a multimeter, check continuity in the timer/cycle control, relays and switches. If you don;t understand electricity, don't mess with it! It can kill you, especially if your dryer power is 220VAC.
Mar 17, 2012 | Dryers
Our Kyocera Mita Copier/Network Printer Model# KM-C3130 when we turn it on we hear a clicking noise and the start button starts flashing but the unit will not turn on.
Check on the machine Screen do you get any Error Code! when you turn the machine on, do you hear the motors running than stops? The clicking noise that you hear does it stop after some minutes?
Nov 23, 2011 | Office Equipment & Supplies
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
When the driver's side window button is pressed, there is a "click" sound from the window motor but the window doesn't move.How do I check the window motor and/or the control console?
While holding the button in the down position with the key in the "on" position tap on the window motor with a hammer. Or if the window is down, hold the button in the "up" position. If window starts working when you do this there is most likely a bad spot on the armature in the window motor or the brushes in the motor have worn out. Hope this is helpful. Good luck.
May 23, 2009 | 2000 Ford Mustang
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
