Question about Aquabot Turbo T2 In - Ground Pool Cleaner
I need to replace the power cord. I have a new
I need to replace the power cord. I have a new one. I see a blue cord going into a black sleeve and a black cord coming out.
The new cord has two small wires with eyes for attachement. Do they attach within the black sleeve? Is that sleeve a shrink covering or something else?
I want to do the minimum disassembly nesseary.
Can you help?
    Problem Solver:
  • 15 Answers
The cord goes into a water-sealed unit on the drive motor internal to your aquabot, so the unit has to be partially disassembed to gain access to the drive motor. The one thing you probably do not have, which you will need to do the job, is the waterproof sealing putty which your supplier can send to you at a small cost. If you happen to be near Phoenix AZ I can help you put on the new cord, and this website gives plenty of info, too: httpp://www.i-love-my-aquabot-automatic-pool-cleaner.com/ S Christian dansker01@#msn.com
Posted on Aug 22, 2009
How do i go about replacing the uv light
obtain proper replacement bulb
shut down entire filter for a moment before unscrewing the top locking ring off Uv filter (left turn) lift top off set asside
using a soft clean rag retract uv tube from its cylinder holder inside , remove power connector from tube end (you should have already removed all power from converter box) with extremely clean rag handle new tube ( allow no forign material to touch outside of tube ) reinsert power connector onto new tube (same way it came off old one) then reinsert tube into holder sleeve , route power cord to proper places away from lid , replace lid and install lock ring back with enough force to ensure a leak proof seal , re start pump ck for leaks if none found then restart power converter for Uv filter
Jun 05, 2015 | Sunterra 300207 Pond UV BioFilter 2000...
I have a Kenmore Upright Model # 11630412001 with a broken power cord
Normally, you would leave the current power connections attached and then line up or label the new cord lines with the old.
There should be a common ground, easy enough to dsitinguish.
A hot, normally black.
A return, normally white.
These may be swapped it the existing wire colors are.
Red = new black
Black = new white
Green or Blue = Green or bare.
I'm a bit surprised t read your post as the cord should have come with connection instructions if the replacement cord is different in color scheme from the old.
ALWAYS TAKE SAFETY PRECAUTIONS WHEN WORKING ON HOT LIVE POWER. NEVER MAKE CONNECTION CHANGES WHILE THE VACUUM IS PLUGGED IN.
IF AFTER YOU CONNECT THE NEW LINES, TEST THIS BY TURNING ON THE VACUUM AND TURNING IT OFF RIGHT AWAY. IF YOU HAVE POPPED A BREAKER OR SEEN BURNING, YOU HAVE TO SWITCH THE BLACK AND WHITE WIRES.
The best thing is to always go online and find the wiring layout for you model.
If you have any doubt, pleast post the wire colors you do see now coming to the connection terminal and post the colors coming out of your new power cord.
Regards,
Worldvet
Jul 05, 2008 | Kenmore 35912 / 35913 Progressive Upright...
I need to replace my electric cord on my Craftsman circular saw. I have the replacement cord and have opened the saw. The new cord ends with just a black and white wire. But the old cords black and white...
my best advice is to sever the wires going into the unit at a point where they are in good condition, obtain a soldering device and solder, some heat shrink tubing addtiquit for the size of wire and connect your new power cord to the these ends, make cretin that the common or wight and the hot witch is black be connected respectively
Good luck and best regards Falco Mueller
Oct 12, 2013 | Saws
Replace chord support sleeve
I think you need to open the back and disconnect the two wires inside. Actually I am looking for that cord sleeve. Where did you find it. I've found a complete assembly for this (Rowenta RS-DX002754)
which is available on line, but all I need is the sleeve.
Good Luck
Apr 14, 2012 | Rowenta Irons
1993 ls400 is starting however it is smoking heavily. the oil and filter was changed and the coolant topped off. the engine light is not on and the dashboard light is going off and on. any ideas???
You don't say what color the smoke is.
Blue smoke means the engine is burning oil, so it has very worn internal parts inside. (lots of miles, or very poor maintenance) Not a thing you can do about this, except rebuild the engine, or replace the engine.
Black smoke means that the engine is running too rich, getting too much gas.- Get a complete tune up.
White smoke means that the engine is burning its coolant, which means that you probably need a new head gasket (Best case) or the block, or piston sleeve, or head is cracked. If cracked block or sleeve, then you need a new engine. If head or head gasket, then you only need those parts replaced.
Jun 25, 2011 | 1993 Lexus Ls 400
I need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 25, 2010 | Rainbow Technologies D4 Bagless Vacuum
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Aquabot Turbo T2 In - Ground Pool Cleaner Logo
958 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
