Question about Kenmore 17382 / 17384 / 17389 Built-in Dishwasher
Knife holder, with knives inserted, falls off when basket closed
No matter how high the upper basket is adjusted, the knife holder will not hold any reasonable sized chefs knife without being knocked off when the lower basket is closed. A simple fix is for kenmore to redesign the knife holder so that it tilts back at a better angle and provide replacements to those of us with this problemI can't believe this problem is over a year old and Kenmore has not yet commented. The only thing seperating one brand from another (in a given price range) is customer service!!!!
Unless and until Kenmore choses to correct the problem, will use plastic ties (such as those used to bind cables and as handcuffs) to remount the holder at a better angle.
2 Suggested Answers
SOURCE: Knife Holder and tine adjuster fall off
This problem would be so easy for Kenmore to correct by simply redesigning and replacing these knife holders....but Until such time as Kenmore responsibly reacts, I recommend remounting the holder to the side of the basket at a better angle using your knife with the longest handle as a guide) usng plastic ties such as used as handcuffs and cable ties. (Not pretty, but effective).
Posted on Jul 15, 2009
How to install a new "upper knife"
First make sure the lower knife edge is the same height as the needle plate.
Then
- Insert the new upper knife into it's holder, tighten the screw slightly
- Turn the hand-wheel until the upper knife is at it's lowest position.
- Move the knife up or down in it's holder so that the cutting edge passes by the lower knife by around an 8th of an inch.
- Tighten the upper knife locking screw well.
May 03, 2014 | Singer 14SH654
How much money should I spend on kitchen knives?
The most important kitchen knives are the paring knife, the cleaver, the fileting knife and the chef's knife. I personally use a German steel paring knife, which costs around $70, but you can spend as little as $20 and get an excellent knife that will do the job. On a cleaver you can spend a fortune, but you can find very good cleavers at around 10$(try at your local market).
On a chef's knife, the Prices for good knives range from around $40 to as much as you care to spend. I use a slightly smaller Japanese ceramic chef's knife and a German steel knife. As a filleting knife, I use a midlevel knife costing around $40. But there are excellent versions available for under $20.
Jul 25, 2012 | Camping, Backpacking & Hiking
German or Japanese knives?
The most prestigious chef's in the world are quite dedicated to Japanese knives but there is still definitely a place in the knife drawer for a high quality German knife. For more information go to http://www.chefsarmoury.com/about-japanese-knives/info_13.html
I'm trying to adjust/replace the knives on my Delta JT160 but cannot get the four screws loose needed to make this adjustment. I've tried penetrating oil several times, WD40 and heat from a propane torch....
Please read my response to another jointer problem here, and heed that advice.
In your case, part #28 is the lock screw/bolt, and part#27 is the height adjusting allen screw. (See parts diagram here.)
I haven't worked on your particular model, but if the instruction manual is any good, it will help you with this task... for that see this link.
Make sure you unplug the jointer before working on the knives.
As you retighten them, make sure the knife is centered from side to side so the cutterhead will rotate without binding, and gently snug up the lock bolts before adjusting the height with the allen screws. Hold pressure on the magna-set, if you have one, so it doesn't move as you raise the knife adjuster up to snug against the bottom of the knife, but don't lift the knife up so high it raises the magnaset or straightedge above the outfeed table. Also make sure you are adjusting the knife when it is positioned at the peak of its arc, i.e. with the cutterhead in the proper position of rotation.
When you have the knife at the right height, tighten the lock nuts, recheck the heights, and make a final check of the lock nuts before moving on the next knife.
Work on only one knife at a time, leaving the others tight while you do so. You don't want to reduce the torque on the cutterhead unevenly.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 24, 2010 | Delta Machinery Jointer Pal,TM, Knife...
How do I change the two blades
Operator's manual for 22-547 portable planer is here.
Page 10 and 11 discusses the process of changing the knives in detail. I'd like to reiterate the manual's comment about how sharp these knives are. Use gloves or be VERY careful.
Per manual:
1. DISCONNECT THE TOOL FROM THE POWER SOURCE.
2. Lower the head assembly by turning handle (B) Fig. 15.
3 Remove chip deflector (A) Fig. 19.
4. Carefully place knife setting gage (B) Fig. 20, on the cutterhead so the rounded sections are directly over the knife as shown.
5. Loosen the knife locking bar by turning the seven knife locking screws, six of which are shown at (C) Fig. 21, CLOCKWISE and carefully remove knife locking bar (D) Fig. 22, knife (E), and springs (not shown) which are located under the knife.
6. Remove the remaining knife in the same manner.
7. Thoroughly clean the knife slots, knife locking bars and screws. Check the screws. If the threads appear worn or stripped or if the heads are damaged, replace them.
8. Carefully replace the springs (not shown), knives (E) Fig. 22, and knife locking bars (D), into both slots of cutterhead (F). IMPORTANT: WHEN REPLACING KNIFE LOCKING BARS (D) AGAINST KNIVES (E), AS SHOWN IN THE CROSS-SECTIONAL ILLUSTRATION Fig. 22, MAKE CERTAIN THE BARS ARE INSTALLED AS SHOWN, WITH
SCREWS (C), POSITIONED AT THE TOP OF KNIFE LOCKING BARS (D), AND ANGLED DOWNWARD HOLDING THE KNIVES (E) PROPERLY INSIDE THE CUTTERHEAD SLOTS. TURN KNIFE LOCKING SCREWS, ONE OF WHICH IS SHOWN AT (C), COUNTERCLOCKWISE JUST ENOUGH TO HOLD BOTH KNIVES (E) IN THE CUTTERHEAD (F).
9. Adjust both knives (see manual).
Jan 17, 2010 | Delta 22 - 547 12" Steel Knife Set for 22...
It seems to be cutting unevenly from left to right?
Operator's manual for the 22-547 is here.
It sounds like you may need to adjust the knives. Page 10 and 11 of the operator's manual discuss the details. See below: (I have removede references to the figure and diagrams in the manual - look there for pictures).
ADJUSTING KNIVES
To check and adjust the knives, proceed as follows:
3. Remove chip deflector
4. Carefully place knife setting gage, on the cutterhead so the rounded sections are directly over the knife as shown. When adjusted correctly, the knife should just contact the bottom of the center portion at each end of gage. Check the other knife in the same manner.
5. If an adjustment to one or both knives is necessary, slightly loosen the seven locking screws, by turning the screws CLOCKWISE into the knife locking bar just enough to relieve stress in the cutterhead and not disturb the knife setting.
6. With setting gage, in place, apply pressure to the knife being reset. Turn the seven knife locking screws, CLOCKWISE until the knife locking bar becomes loose. Lift springs will automatically raise the knife until it comes in contact with gage. Snug the knife locking bar by lightly turning the seven locking screws, COUNTERCLOCKWISE.
IMPORTANT: AT THIS TIME, ONLY TIGHTEN THE KNIFE LOCKING BAR JUST ENOUGH TO HOLD THE KNIFE IN POSITON INSIDE THE CUTTERHEAD SLOT.
7. If the other knife needs adjustment, repeat STEP 6.
8. After both knives are positioned in the cutterhead, turn each of the seven screws, COUNTERCLOCKWISE until the knife is secure in the cutterhead. NOTE: When tightening knife locking screws, tighten the end screws first, then inward toward the center of the cutterhead.
9. Replace chip deflector.
Jan 12, 2010 | Delta 22 - 547 12" Steel Knife Set for 22...
Thickness planer
I was able to make a knife setting jig for the Delta planer using magnets and measuring the old knife setting height abouve the knife holder before I removed the knives.
Mar 23, 2009 | Delta Tools & Hardware - Others
No running manual 4 summasign pro D610 vynal cutter
You can get assistance and possibly a manual for your Vinyl Cutter from a Summagraphics Repair facility such as
ADVANCED GRAPHICS
1027 N. MAIN STREET
TEL: 210-227-9393
SAN ANTONIO, TX 78212
I hope this helps. Toni Gallucci, Glass Act
Mar 17, 2009 | Computers & Internet
Nov 01, 2008 | Kenmore 17382 / 17384 / 17389 Built-in...
Upper Knife
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Kenmore 17382 / 17384 / 17389 Built-in Dishwasher Logo
43 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
