Question about Yamaha HTR-5440 Receiver
Yamaha HTR 5440 will not power up!
I have a Yamaha HTR 5440 unit that I have had for several years. Recently it stopped powering up. I took the cover off it and did not notice anything burnt. The fuses were good and I had power at the power supply rectifier bridge. When I turn the unit on, there is a click and no display. None of the functions work.
  • 85 Answers
SOURCE: I have a Yamaha htr
Yamaha av amplifiers have a high failure rate needs to be serviced
Posted on Jan 19, 2009
heavyice
  • 374 Answers
SOURCE: Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Posted on Jun 02, 2009
  • 14 Answers
SOURCE: Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
Posted on Sep 08, 2009
  • 4234 Answers
SOURCE: When push the power button, I can hear a relay
When the unit functions correctly, you should hear 2 clicks. The first is the power relay that "starts" the unit. The second is the speaker protection relay that will kick in the speaker connection. If you do not hear the second click, the unit is in protect mode. This means that a problem was detected in the amp section and the unit is prevented from connecting the speakers. This is done to prevent further damage. Typically the output transistors fail and cause this. Expect a parts cost in the $25-$50 range for this repair.
Dan
Posted on Sep 30, 2009
electrotech1
  • 1126 Answers
SOURCE: I am troubleshooting a HTR-5830
Check for shorted out put transistors that is pulling your voltage down.
Posted on Dec 22, 2010
The Sub-woofer output on my Yamaha HTR-5440 keeps dropping out!
may be dry joints on electronic components, consult a technicia for resoldering the pre amp or amp unit,
Feb 03, 2014 | Yamaha HTR-5440 Receiver
How to reset a yamaha 5440 reciever back to factory settings
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
Dec 30, 2012 | Yamaha HTR-5440 Receiver
Location of fuse in yamaha htr 5840 receiver
This is old, but unplug the unit, remove the cover and check the vertical power board where the plug wire enters. There are two fuses on this board, both are 8A125V. These are the only fuses in the unit.
Jan 25, 2012 | Yamaha HTR-5840 Receiver
Jun 02, 2009 | Yamaha HTR-5440 Receiver
Yamaha HTR-5230 will not power on
check yhe fuse inside the unit?
Jan 03, 2009 | Yamaha HTR-5730 Receiver
Powers on for just 5 seconds then off
Took my Yamaha HTR 5790 to a repair shop for an estimate to repair. Cost me $50 for estimate to be applied to repair. It needed two circuit boards replaced at a cost of $390.00.
SOLUTION... they kept my $50 and I bought a new AV Receiver that WAS NOT a Yamaha.
Aug 23, 2007 | Yamaha HTR-5790 Receiver
Remote will not work on my reciever
I am wondering if it a preprogrammed remote controller or not. If not, you have to reprogram it.
Jul 03, 2007 | Yamaha HTR-5440 Receiver
Check sp wires?
Your problem most likly is not because of dust. Its a bad connection in the amp section or the protection circuit, or the speakers them self have a problem. There could also be a componet problem. Unless you know how to troubleshoot solid state electronics,you should take the unit in to be serviced. It would most likly cost more then its worth to repair. A unit this old is u replaced at this point. Good Luck
Aug 05, 2006 | Yamaha HTR-5440 Receiver
Yamaha HTR-5440 Receiver Logo
186 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
