My BIOS reset itself, and I don't know the password. System #DHMGP51-595B
  • 13,433 Answers
Take out the memory battery for a hour. The motherboard will most likely also have a jumper that can be used to remove the password but removing the battery for atleast a hour will remove it.
Posted on Jul 15, 2009
I bought acer aspire 3680 used had to do a system restore on it 2 weeks ago now it asks for windows password of prior owner which i dont have but i used this pc for 6 months wouldnt my windows passwor
If you can't change the setting in the bios setup that means you have a bios supervisor password set. If you don't know the supervisor password you can reset the supervisor with Acer Bios Master Password from http://www.unlockbiosrecovery.com/Unlock_Acer_Bios.php for only $20
Jul 16, 2012 | Acer Aspire 3680 Notebook
I don't know my security code
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
hope this helps you
Aug 26, 2011 | Computers & Internet
My laptop HP ProBook 4510s prompt computer open password befor going to BIOS or OS. And i don't know what is the password? So how can i reset the password to boot the computer.
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps you
Jul 25, 2011 | HEWLETT-PACKARD 574508-001 - Original HP...
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
My sister gave me a Compaq evo computer. When i turn it on it goes right to a screen that says Power-on password with a picture of a key. She doesn't know what the password was and it doesn't let...
It seems to be BIOS password, if you don't remember or don't have the BIOS password you have to reset the password by opening your CPU cover and removing the CMOS coin battery, this will reset the BIOS password but dont forget to return back the battery and start using your PC.
Regards,
JJ
May 15, 2011 | Compaq Evo D500 PC Desktop
Toshiba satellite a135-s4656 reset bios
Even though I suspect that your system restarting
itself is not only caused by a BIOS error, but I will
still tell you how to reset your system BIOS:
If you don't know the system password for your
System, forgotten it, or its not accepting it again,
then you might have to reset your CMOS (BIOS).
Which means you will have to unscrew your system,
remove all cables supplying power to the board,
locate the CMOS battery(a small battery plugged
into a socket there) and remove it for a few
seconds, then replace it and screw your system
back.
This will reset your system's CMOS back to its
Factory default settings.
(If you cant unscrew your PC yourself, you can just get a good technician to do it for you instead.)
Hope it helps.
Feb 06, 2010 | Computers & Internet
Acer bios reset
Please remove the CMOS Battery from the Motherboard for 10-15 seconds and re-insert it.After that system BIOS will without password and default setting .configure system BIOS according to your requirement.
Nov 19, 2009 | Computers & Internet
Advent 7109b Laptop System Password (set by itself) After three incorrect tries. shows the message ''System Disabled [04762]'' Machine has the Phoenix Bios (Dixons) Bios:- 1.06.04 Dix Ec:- 1.05.01
You have to reset bios.
But first try defaults password "phoenix'
try this then if still not enter then open back side of laptop cover ,
you can find 1 cmos cell on motherbord chipset.
Pull cmos cell for 10 minutes then all settings are defaults.
So thne it not want password.
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
