Question about Ricoh Aficio 450 Copier
Fucntional problem with Savin 4022 sp, SC 120. Did clear mode to get to sp screen but copier still will not turn off..
Remove paper from internal tray of savin 4022 copier?
Posted on Jul 21, 2011
  • 162 Answers
Scanner home position error
The scanner home position sensor
does not detect the on condition during
initialization or copying.
• Scanner drive motor defective
• Scanner motor defective
• Harness between SBCU and
scanner drive motor disconnected
scanner drive motor power source
disconnected
• Scanner HP sensor defective
• Harness between SBCU and HP
sensor disconnected
• Scanner wire, timing belt, pulley, or
carriage defective.
Posted on Sep 22, 2009
  • Ricoh Expert
  • 393 Answers
This is a scanner problem (the part with the lamp) is it crooked as viewed from the orig. glass? No need to reset this code when the movement problem is fixed turning power on and off will reset. -Carl
Posted on Jul 15, 2009
Is there any way to reset the thermal fuse - it was just working fine, and then it said paper jam, now I get the SC-542 error code - how do I reset it first or get in the setup mode to reset the jam...
firs you go to SP mode while pressing
Starting SP Mode
1. Type the keys as follows:cleare mode button which appers in yellow color and continue the numbers 107
2. Press the cleare button which appers in red color and hold it down until the SP-mode menu is displayed (about 3 seconds) then switch OFF the machine and switch ON this process re-set the code -thanks
1 2 3
4 5 6
7 8 9
0 #
Jan 03, 2011 | Savin Office Equipment & Supplies
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
Oct 26, 2010 | Ricoh Aficio 1035 Copier
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
How do you reset the savin 8035 sc542 code after thermistor is replaced?
Press the yellow button ( reset button ) then press 107 then press and hold the red button (stop button ) for about 3 sconds until the display changes. Touch copier on the display screen. Now turn the copier off using the on off switch on the left front side of the copier. If the cold comes back the Thermostat in the fuser is most likely tripped and would need to be replaced.
Apr 29, 2010 | Savin 8035e Copier
SAVIN C36535 SC365 FUNCTIONAL PROBLEM WITH COPIER PLEASE HELP
Hello sir; SC 365 it means megenta TD senser defect or megenta PCU( drum unit).
Feb 05, 2010 | Office Equipment & Supplies
Savin 816 photoconductor troubleshooting
Enter the SP mode.
Clear Mode 1,0,7 Hold down the Clear/Stop Key. Select Copier SP the go to SP7 - Data Log, then go to 804 and hit enter/execute. This will clear the PM Counter.
Sep 01, 2009 | Ricoh Aficio 250 Copier
Resetting the photoconductor unit
You need to enter service mode and the # is SP 5-912-1 set this to 0 (to get in to service mode press in sequence clear modes 1 0 7 and hold red stop for 5 or so sec. At the top of the screen should be direct SP highlight this and press the 59121 and it will take you right there.-Carl
Jun 28, 2009 | Savin 9935DP Laser Printer
Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
May 29, 2009 | Ricoh Aficio 450 Copier
Error Code 546 in Savin 3540 copier
enter sp mode with the following combination
yellow key then 1 0 7 and hold down stop till the screen changes go to copy sp then scroll down to 7 datalog and down to 897 sc jam reset and execute the turn off the machine and back on
Dec 27, 2008 | Office Equipment & Supplies
Sc code
Go to sp mode press Clear Modes 107 and press Clear Stop for four seconds. Screen will change enter to SP Modes. enter 2109-1 and execute. then enter 2109-2 and execute. That should do it.
Nov 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Ricoh Aficio 450 Copier Logo
691 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
