Question about Philips 51PP9303H Rear Projection Television
Tv will not change imput to AV5
Philips 51" 51pp9309h/17
i can't seem to access anything that get plugged into AV5
How do i hook up my i pod up to a mcm530 philips stereo system?
If it has an aux imput all you need to do is get a dock (which will keep the battery charged while playing) or the cheaper way - by connecting a 3.5mm plug to two RCA phono plugs- lead. The 3.5mm plug goes into the headphone output of the I-Pod and the RCA's go into the Aux imput of the Philips.
It can be any imput on the amp (except phono) such as CD or tape.
You will find that you need to turn up the volume on the I-Pod to hear the sound.
Mar 08, 2010 | Philips MCM530 CD Shelf System
I have an DVI to HDMI cable running to my Playstation 3. The playstation reconizies the connection. When I search the tv for the connection I connot find it.. The back of the tv says the DVI input is...
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Dec 03, 2009 | Philips 51PP9100D 51 in. Television
Which board is it?
tell me what your tv is doing and ill try to go through everything with you on it
Sep 03, 2008 | RCA D61W20 61" Rear Projection Television
Hooking up computer to philips 60pp935217 AV5 HDTV connector?
Hi Roger,
Initially, pls try lowering the screen resolution of your PC. This can be done at the Display Properties/Settings tab and then move the slider of the Screen resolution towards the left, Apply OK. In some instances, you need to also lower down the Screen refresh rates in the Monitor tab of the Advanced Properties.
If your concern has not been corrected after completion of the above procedures, then other methods can be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 15, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
No av5 in menu
it becomes visible after you hook up a dvi to hdmi adapter
Jan 01, 2008 | Philips 51PW9363 51" Rear Projection...
Philips Projection model #51PP9303H17 AV5 input not working?
After many hours of research, I was able to fix the missing AV5 channel. I had to access the service menu using code 062596 and the Status/Info button on the Philips remote. There was an error message that had to be cleared and then AV5 needed to be turned on in the options menu. While I was in there, I also turned on the WSCR option, giving me two additional wide screen aspect settings that had also disappeared. I advise you not to go into the service menu unless you do your homework and document each setting before you make changes. Good Luck!
Nov 29, 2007 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
