Question about Volkswagen Golf Vw Diecast Model
The back wheels feel like they are sliding left to right when i drive in a straight line, also feels like someone is breaking sometimes? I have had 4 new tyres fitted and car still seems to slide around like when you get blown about on a windy day!
  • everett25077 Jul 15, 2009
    It was already doing it before thats why the garage changed the 4 tyres. Now im starting to wonder whether its the rear axle bushes??
  • 867 Answers
Sometimes when you get tire changes, you need to get a 4 wheel alignment, but sometimes rotating tires around will do.
Posted on Jul 15, 2009
Why is car vibrating loud and hard when I turn the wheel towards the right?
sounds like its the wheel bearing assembly on one of the left hand side wheels recheck that there is no play on those wheels when jacked up off the ground and spin both wheels by hand .......your sure to feel a roughness on the problem wheel on fast rotation by hand
Aug 19, 2014 | 1999 Chrysler Sebring
Pulling back and forth in steering almost feels like in 4 wheel drive
Could the front control arms be worn out and letting the differential shift around ?
Sep 26, 2012 | 1996 Ford F250 Crew Cab
When i drive, it feels like i have little control while the steering wheel feels loose. I also have to turn my steering wheel about 15degrees to the left to go straight. Any ideas?
Sounds as if you have bent some control arms Or even broken the steering gear rack both front wheels must be off the ground to ***** the situation The best way to recognize a bent part if you are not familiar with it is to compare to the opposite side
Mar 02, 2012 | Saturn Cars & Trucks
Noise in front end when going straight or turning right. Noise stops when you turn left.
i would check the right front wheel bearing . Jack the right side up and feel the tire pull back and forth and see if the tire feels loose if it does the wheel bearing is junk. only other thing check the cvc axel.
Mar 26, 2011 | 2007 Buick Lucerne CXS Sedan
Steeing wheel vibrates when i turn to the left from a stop
Does it feel like it's trying to pull back straight? if so, I would say you have a seized strut bearing on the right side.
Jun 02, 2009 | 2006 Chevrolet Impala
The break small cylinder is leaking at the right side back.
just keep in mind brakes are a saftey item.
if you could have both rear wheels and drums off then dis assemble linings then remove wheel cylinder and replace, assemble up the same as other side to copy. borrow some maintenance repair books from library or google procedures from manuals with drum brakes all have same principals.some front wheel drive vehicles have wheel bearings that need repacking with grease when removing drum and hub as one and more importantly have the do up nut by feel rather than torque up to setting hub nut and some drums come straight off from hub leaving bearings and hub on vehicle.
tools
garage jack, saftey stands, wheel brace to remove wheel nuts, brake hose clamp, side cutters(pliers),flat head screw driver, hammer, socket set, spanner set,mostly 10mm ring and open ended spanner for wheel cylinder
May 30, 2009 | 2000 Ford Taurus
91 4runner 4 wheel drive problems
Check that your front right brake caliper isn't dragging: coast to a stop, and check if it is hotter than the left.
check for even tire pressure and tread wear on each tire.
check axle alignment by measuring distance between front and back tires on each side, they should match.
if none of these fixes it you may have a partially seized bearing on your front differential
Feb 12, 2009 | 1991 Toyota 4Runner
2000 Jeep cherokee steering wheel alignment
to remouve the steering weel and drive the vehicle slowly look on fordwar in line and replace the colum ,, the noise must came from the adaption that you made . raise the vehicle and see were is any part for the suspention that toutching the chassis and ajust it......
Dec 22, 2008 | 2008 Jeep Wrangler
Problem with my brake system
sounds like your servo is at fault try bleeding all 4 wheels with engine running right wheel warped disc
Nov 16, 2008 | 1989 Ford Thunderbird
Volkswagen Golf Vw Diecast Model Logo
119 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
