Question about Vizio L32 32 in. LCD HDTV
42 vizio power supply
How hard is it to change it
  • lsnow Jan 07, 2008
    42 plazma get audio but no picture
No output from Supply, check fuse, ok. Where can I get a new power supply? Set is 2 years old.
Posted on Dec 21, 2008
    Problem Solver:
  • 7 Answers
The power board is very easy to replace, but from my experience it seldom goes bad on these sets.
Posted on Dec 14, 2007
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: Standby power usage of the 42" Vizio Gallevia?
According to a Cnet review of the 42" Vizio Gallevia, the standby power usage is only .75 watts. Because it is so low, I now have no concern about leaving the set in standby mode. Virtually no savings to be realized by unplugging the set between usage.
Posted on May 19, 2009
SOURCE: Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Posted on Oct 21, 2010
I have a vizio 42 model vp42hdtv and the screen is dark red I have sound
VP42 HDTV Will not power up. Changed power supply board and power cord. Still nothing
Apr 12, 2011 | Vizio 42 in. LCD TV
Vizio 1080p model VU42LFHDTV10A clicking and blackish/ gray screen no picture
have you tried changing the "input" button is on lower left corner. If you have a DVD/VCR hooked up, change input to that, if still same thing then the high voltage power supply might be bad.
Mar 31, 2011 | Vizio 42 in. LCD TV
Thr screen looks wavie . How do I adjust or tighten the screen
problem power supply , you need to change the poufed capacitor or change the power supply board
you must have idea about electronic , good luck
Jan 07, 2011 | Vizio 42 in. LCD TV
Vizio vw42lhdtv10a 42" vizio will not turn on the vizio light is orange when tv not on and white when tv is on it turns white but i get no video or audio the screen doesnt change like it even wants to come...
check out the power supply board! Look for popped capacitors. They either leak or swell up. They are the can shaped things on the board with the plastic coverings on them...you can usually see a swollen cap sticking up over its covering as a telltale sign.
Good luck and be careful
Mar 16, 2010 | Vizio VW42LF 42 in. LCD HDTV
We think lighting struck ur house and now my 42'' vizio flatscreen tv does not come on only power ligth?
I would replace the power supply board-you can get it from shopjimmys.com
enter your model number-scroll down til you find power supply-you can replace it yourself-simply plugs in
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
42 Vizio LCD Tv-
Replace the power supply will fix the problem. Is the Vizio LED light on?
Jan 19, 2009 | Vizio GV42L 42 in. LCD Television
Vizio 42 inch tv Power Not working
It sound like the power supply problem. Replace the power supply will fix it. The power supply is located near the main board.
Dec 15, 2008 | Vizio GV42L 42 in. LCD Television
Vizio 42" plasma tv model#p42hdtv10a
yes,veryry possible you have a bad transister on the power supply board .best way to fix it is to change the hole board.
Oct 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Power supply
Have you checked Vance Baldwin? They are the ONLY parts distributor for Vizio.
http://www.vancebaldwin.com/
Apr 25, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
276 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
