Question about Yamaha RX-V661 Receiver
Right speaker dead on zone 2 on my RX-V 1600 receiver
Good Morning: My Yamaha receiver (RX-V 1600) had a problem where I lost the right speaker power on the Patio zone on the unit. They came out and replaced the unit under warrantee. Unfortunately, the problem is back, no sound on the right speaker in my patio. I checked the speaker and it works fine when plugged into the left speaker wire. What do I do? and How do I do it?\r\n
Thank you
    Champion:
  • 287 Answers
Must be the right speaker wire, sounds to easy I know but maybe your wiring is grounding out the audio to that channel.
Posted on Jul 16, 2009
No sound from zone 2 speakers on yamaha rx-v661
Have you gone into the speaker configuration menu and turned on zone 2?
Oct 18, 2013 | Yamaha RX-V661 Receiver
The receiver shuts down when zone 2 is turned on
Disconnect the speakers on Zone 2 and try to turn on the receiver again. If the receiver works, there is a shorted speaker wire, pinched wire, or a blown speaker on zone 2. Good Luck
Jul 01, 2007 | Yamaha RX-V657 Receiver
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
I cant get zone 2 to work on my yamaha rx v673. They are 2 outdoor speakers.. please help
I had a similar problem where I could not increase zone 2 volume - Page 100 in the manual notes that 'power amp assign' must be set to "7 Ch + 1 zone" before zone 2 max volume can be changed. Try that.
Jul 08, 2012 | Yamaha RX-V663 Receiver
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
Yamaha RX-V2500 completely shut down
Sounds like the volume control on zone 2 is your culpret. You should set up zone 2 to have a "fixed" output instead of "variable" it's in zone 2/3 setup. whats happening is you are overloading the volume control from the zone volume on the receiver and getting feedback to the receiver and shorting it out. What you do is put zone 2 to fixed output. set the vol control to 3/4 then adjust the vol to relatively loud and exit out of settings. this will be your max volume setting. Now, on to your problem.Unplug the receiver. There is an internal fuse that could have blown, not to likely but it's possible. You have to take the top off the receiver with a #1 phillips or a T10 torx they vary. It's about 7 screws, pop off the top and look from front to back, you will see 1 or 2 fuses near the AC plug port. Sometimes they are gray or white and you cannot visibly tell if it's bad. If you have a multimeter, set it tone resistance. Then put your leads on either side of the fuse, if you hear tone the fuse is ok. If not check your leads by touching them together and you will hear tone then test again. If you don't have tone, your fuse is bad. Radio Shack should stock the fuse you need. If you don't already know this, there are 2 Power switches for your unit. Front of receiver bottom left corner "Master Power" and normal Power switch "Main Power" check them both. If your fuses are good and power is good, you have bad transistors internally and it needs to go to service. check www.yamahausa.com support and service, and you can find the closest authorized service center to send it to. If you mail it out directly to the service center rather than taking it to a dealer, you will save some money and get it back faster. Lastly, pull your zone 2 volume control and look for black marks on it or white chalky substance. "oxidation". If you don't mind spending a little money on the system, hardwire the speakers thru and replace the volume control with an IR receiver. If you could control the zone from the zone by pointing the remote at the volume control you had an IR vol control. You really didn't need the vol part. Xantech or Proficient make good IR receivers that aren't too expensive and will keep this from happening again. If you need any more help, I am a Yamaha Dealer, let me know where your located and I can send you to a good service center. Just post a comment and I'll get you the info you need. Hope this helps
Apr 19, 2009 | Yamaha RX-V2600 Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
NO sound on Zone 2
Did you use the same terminals or two different ones to make the connections?
May 18, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V800 Zone 2 Operation
yes it works great. hook them up to zone B. then below the power button is a A/B button. select button B and then zone B will work.
heres the manual if it helps
Apr 02, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V661 Receiver Logo
135 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
