Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
When i hook it up i get the laptop to pick up the signal but the desktop will not go online
  • 390 Answers
On the hind side of the modem how many ports do you see
my guess one port slightly seperated and named INTERNET or WAN and four more ports numbered 1,2,3,4
now connect the network cable from the modem to the WAN / INTERNET port and connect the laptopand PC to the ports1,2
now check to see if there is connection to only on Laptop or both
but if you have conection to only the laptop/PC connected to port1 then try this small trick
move the laptop to port 3 and in port 1 connect the cable from the modem which was connected to the WAN / INTERNET port
and u r set to go
Posted on Jul 15, 2009
  • 24 Answers
Are you trying to use the router's wireless capabilities from your desktop PC? You will need to have a wireless network card installed on the desktop. If you are using a wired connection to the router, make sure the connection is firmly in place on the PC and the router. Also try a different port on the router to see if that connects.
Old LCD monitor detected by but not getting a signal from AMD-run desktop
start in safe mode press f8 on power up go to control panel and go to display control panel varies on operating system screen resolution & frequency to high set at 800 x 600 resolution at 60 hz and you may get a picture
May 22, 2014 | Hannspree Hsg1106 20-inch Widescreen Lcd...
My laptop stopped picking up wifi after a much needed modification. I have a 3 year old hp pavilion dv9000. the hinges broke so I decided to remove the monitor of the laptop and hook it up to a desktop...
That is because the WI-FI antenna wires were on the LCD panel behind the glass.
Currently your laptop base has no signal. The only solution is that you may pick up a signal with the base alone, if it is near the wireless router about 20' (3 meters).
Apr 19, 2011 | HP Computers & Internet
I can log on to my wireless account and get online, but then it i lose the signal, and when i scan, it picks up signal stenght on 90 % but wont connect, I can hard wire it and i get online with no...
The problem lies in the wireless connection. Either the wireless adapter on the game console, or with your wireless router. Although wireless internet makes it easier to get online and play, it is actually the worst choice for online gaming. this is due to the lag time in the signal relay to the router. Wired internet is the best choice for online gaming. If you can hook your console up to a wired internet connection, then I suggest you do that.
Jan 18, 2011 | Video Game Consoles & Games
Will Dell Inspiron laptops pick up 802.11 wireless network?
I'd get the N-wireless card. It makes your signal much stronger, you pick up more signals, and you have less interruption. You won't get to see the full benefits without an N wireless router, but you will still notice an increase with a G router. I have an N wireless USB adapter hooked up to my desktop right now and I get 1-2 extra bars than I do with my laptop in the same spot (which has a G wireless card).
Aug 28, 2009 | Computers & Internet
My router is hooked up correctly on my desktop and my laptop shows it is connected with a strong signal, but I still cannot get online, any suggestions
If you can't get online on either machine, plug your ethernet cable directly from your cable or dsl modem into your desktop. If it shows a network connection and you still can't get online, it may be a service provider problem. I am assuming that your service provider did not ship you a router, only a modem. Hooking up 2 routers on the same connection can be very tricky.
Jul 30, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
Do Desktops pick up internet connection like laptops do? Im planning on purchasing a desktop pc however im not sure if i can pick up internet like my current laptop does, U see i just moved in and dont...
Hi there.
You hit the nail right on the head!! desktops don't come wireless enabled so you will need a wireless card installed into it.
I recommend a wireless PCI card as a Dongle are not that good and can be easily broken.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Computers & Internet
Desktop won't pick up my wireless internet signal
the desktop has to have a wireless card if it does not it wont pick up
Mar 31, 2009 | Dell OptiPlex GX260 PC Desktop
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
My laptop has suddenly stopped picking up the wireless signal from our Belkin router so I cannot work online. I have tried everything I know of to try and get it working short of going to the online site...
Try disabling your WiFi switch and turn it on again, if this doesn't help, try uninstalling the WiFi Driver and re-install it. Sometimes placing your laptop too far from your Router gives you a weak or sometimes no signal, when solving this problem please make sure you were near enough to your router.
Jun 11, 2008 | Belkin Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
228 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
