Question about Sony PlayStation Portable (PSP) Console
My sony psp 3000 is not identifying my home wifi signals, but I wlan is switched on, I can see other networks when it scans, I don't understand what's problem
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 151 Answers
There are types of wifi signals psp work. Maybe your wifi connection is not that type.
Posted on Jul 15, 2009
How can i upgrade my psp for free?
You will need to get a wireless connection that has no WEP code or know the code of a router of your own. If youve turned on the Wlan switch at the top it should pick up signal that can connect you to the internet. Here is guide.
  • 1
    On the lower left-hand side of your PSP, you will notice a little silver slider. Slide the switch up and this will turn on the WiFi feature on the PSP. Of course, you do need a home WiFi setup for this to work. Your battery also needs to be full. Even if your battery is low and your unit is plugged in to an outlet, the firmware upgrade may not work.
  • 2
    With a fully charged device, go to your PSP's home screen and choose "Network Update."
  • 3
    This screen will ask you for your WLAN settings. Choose "Scan" and let the PSP detect the network automatically. Choose the right one and keep all of your settings in the default stage. Press the "X" button and the PSP will save the configuration as your new access profile.
  • 4
    Choose it again and when your PSP connects to the network, and if there is an update available, you will automaically see the following message: "Network Update has found a later version. To download, insert a Memory Stick with at least 14MB of free space and press the X button."
  • 5
    Press the "X" button and you should see the message: "Downloading." IMPORTANT - Do not turn off your PSP or remove the memory card during this time!
  • 6
    When the download is finished, you will see the following message: "Download completed. The update is now available on your Memory Stick. To install now, press the x button. To install later, go to [Game]." Press the "X" button to install the new firmware. You may see a few other screens detailing new features to be included in the upgrade, but eventually you will see "Installing."
  • 7
    During the installation, again, do not turn it off or remove the memory card. Once installation is finished, the PSP will tell you to press "X" to restart the PSP. When it powers back up, the new firmware will be in place
  • Read more: How to Upgrade Your PSP Firmware ' eHow.com http://www.ehow.com/how_2288266_upgrade-psp-firmware.html#ixzz1XnkoKCiw
    Sep 13, 2011 | Sony PlayStation Portable (PSP) Console
    I have a new psp and and to connect to the internet i need a ssid code but i didnt get one when i bought it
    A service set identifier (SSID) is a name that identifies the network. To connect to a wifi network with your PSP follow these steps:
    1. Flip the WLAN switch to 'ON'
    2. Select Network Setup from the main menu after that select the Network Settings
    3. Select Infrastructure mode > Create new connection
    4. Select Scan and choose your WiFi`s SSID (name)
    Mar 17, 2011 | Sony PlayStation Portable (PSP) Console
    Sony PSP 3000 will not connect to wifi
    Hi tee_singh,
    Based on your concern, I suggest trying the following steps:
    1. Turn your PSP on.
    2. Make sure that your WLAN switch is turned on.
    3. Perform a factory reset.
    --> To do this, select "Settings", then select "Restore Default Settings". You will not lose any information or data by performing this step.
    However, you may need to reset your wallpapers. Set your name, date, time, etc...
    4. Power down your PSP then wait 10 seconds, then power it on.
    5. Navigate to "Network Settings".
    a. Select "Infrastructure Mode"
    b. Select "New Connection" Name this connection as you deem appropriate.
    c. Navigate to "WLAN Settings" Select "Scan".
    d. Your router should now be listed.
    e. Navigate to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None"
    f. If you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA..
    g. Navigate to "Address Settings". Select "Easy"
    h. Navigate to "Setting List". Verify that your settings are correct.
    i. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
    j. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
    Hope it helps,
    Thank you for using Fixya.
    Feb 03, 2011 | Sony PlayStation Portable (PSP) Console
    Want to know how to connect my sony psp 3000 to wifi netwrk
    Hi akshthal007,
    Hope it helps,
    Jan 24, 2011 | Sony PSP-3000 Silver Console
    Why i can't access internet on psp
    1.] Check if your wlan switch is turned on...
    2.] Have your console scan for wifi connection through infrastructure mode in the internet settings option...
    3.] If problems persist... You may have a defective wlan switch...
    Oct 09, 2010 | Sony PlayStation Portable (PSP) Console
    Every time i try to connect to my wifi network on my psp it wont connect
    1. Turn the WLAN switch on the PSP to "on" (it's a silver slider switch on the lower left *edge* of the device)
    2. Access to a wireless Internet network that doesn't have a password.
    Then you should be able to 'scan' for networks, pick out the one you want to use, and go online.
    [Note: While the PSP supports various wifi password schemes, notably WEP, I haven't had any luck with password-protected sites myself and haven't heard from others that it worked either]
    Sep 09, 2010 | Sony PlayStation Portable (PSP) Console
    Psp 3000
    You have to configure the system to your WiFi by searching for a wireless access point and following the dirrections on the PSP. You must also flip a switch on the top of the system that says "WLAN" to turn on the WiFi.
    Jul 28, 2009 | Sony PlayStation Portable (PSP) Console
    How to get wifi connection in my home???
    First make sure your WLAN is switch on. Next go to network settings -> Infrastructure Mode -> New Connection -> Scan. It should scan all available connections and compile a list, you should see your home network here, click it and proceed.
    May 13, 2009 | Sony PSP (Piano Black)
    How to connect my PSP to the internet?
    you need a router, the modem to the router, the router must be wireless, that sends the signal to the PSP, if it is WiFi. The modem itself is usless, without the wireless adapter or router to send the signal to your PSP
    Dec 18, 2008 | Sony PlayStation Portable (PSP) Console
    Can't get onto the internet
    it say wlan is not on so find the swicht and turn it on
    Oct 05, 2008 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    863 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
