Question about Gateway MT3422 RTL Notebook
Willl not power on
I have tried to remove the ram and power it on and all lights come on briefly and then turn off. If I keep pressing the power button, the cd-rom light will come on and you can hear it spin, and also the cpu fan will kick on for a while as well. Is there anything else I could try? Any help would be appreciated!!!
  • Luke Stewart Jul 16, 2009
    Thanks Avid,
    I just had it in for repaired by Gateway last month and they had replaced the board and ram. Could it just have gone bad? I think I have 1gb and Vista 32 bit, I had noticed it was running really hot, could it have been a processor issue?
  • Gateway Master
  • 6,487 Answers
This is usually a processor overheating that will cause further damage like this , because when a computer encounter a overheating problem , this will also make the MOBO to go bad and will lead to this type of problem, You can also try to remove the RAM and boot the computer so we can see if it will even create a beeping sound if after that still the same problem try checking the processor or better try a different one....
Posted on Jul 20, 2009
Micromax a90
Hi, try these. press power and volume down button for 10 sec. Then try to power up it by briefly pressing power button. if fails, press power and volume up, be carefull , when the screen comes live - not to select any other option but only normal boot. To select a option press volume up button, it will power off, then power on again by pressing power button. it may fail by keep trying and in between keep charging ..
Thanks
Jan 16, 2014 | Android Cell Phones
Willl not turn on
It may be stuck in a cycle. Try removing the battery and power unit. Press the power key repeatedly for around 15seconds. Plug in the charger and power on.
Dec 03, 2013 | HP Mini Computers & Internet
My hp probook wont turn on - the power-light keeps on flashing (white)
Remove batterry. Keep power button pressed for 30 seconds. Put battery back. Power on. Check RAM Memory for problems. Try another RAM memory. Please post results. Thank you
Oct 31, 2012 | HP Computers & Internet
How can i bypass my forgot admin password on my compaq armada e500
With the older Compaq Armada E500 Notebook PC, I believe;
1) Remove the CMOS battery.
2) Leave it out for 30 minutes.
3) Press the Power On button, and hold it for a count of 10 seconds. Let go of the Power On button.
Press it again. If the Power On light comes on, hold the Power On button in, until the light goes out. Keep pressing, and holding the Power On button in, until the Power On LED light does Not come on anymore.
Reinstall the CMOS battery. WAIT 1 minute, turn the laptop on.
If this doesn't do it, there is a capacitor inside the laptop keeping residual power. There may be two copper pads that are briefly touched across, to dissipate this residual power.
Perform the removal of the CMOS battery first. If this doesn't work I'll try to find info on the copper pads. (They are usually under the Wireless Card, and a small piece of Mylar plastic sheet)
Post back in a Comment as to your findings.
Regards,
joecoolvette
Jan 22, 2012 | Compaq Computers & Internet
The laptop was turned off improperly and the power light is on but there is nothing oon the screen
Try pressing and holding the power button down until the power light goes off.
Once it is off, then try to turn-on the laptop as usual.
If this does not work, remove the power cord and the battery from the laptop, and then press and hold the power button down for 30 seconds.
After the 30 seconds, release the button, install the battery and re-connect the power cord. Start the laptop as usual by pressing the power button briefly.
Dec 29, 2010 | Computers & Internet
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
My dell pc laptop is not coming on
If power is not coming in the notebook try following:
1.Remove the battery and check on ac mode if coming battery faulty.
2.If then also no response means mainboard is having the issue.
If the power is there and no display:
1.Refix the RAM once and RAM chamber willl be on the backside.
2.If the lights are not responding then the issue is with mainboard.
Thanks
Dec 10, 2009 | Dell Computers & Internet
Laptop will not start...
2 words: Memory. Motherboard. Check to see if the memory is properly seated by removing the memory cover on the bottom of the laptop. Gently move the two release tabs until the RAM module pops up. Then, gently pull the RAM module out and put it back in, with the gold connectors facing the metal "lip" you just took the module out of. Press down gently on the other end of the module until you feel it click. Replace the cover, and attempt to turn the computer back on.
If this does not work, take the computer in to a service technician or call HP at 1-800-474-6836 and they will do their best to fix the problem.
May 04, 2009 | HP Pavilion dv6000z Notebook
Gateway MT6451 Does not turn on
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
Wont stay on
I suggest removing the battery when plugging it to the wall outlet or are you trying to charge it? I think the one that is spinning is the hard drive reseat it then lets see what happens try to purchase a new hard drive if problem persists. please indicate also the status of the lights on your laptop ill reply with more steps when you've indicated everything
Mar 22, 2007 | Dell Inspiron 1100 Notebook
Gateway MT3422 RTL Notebook Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
