I need to retrive the key operator code for a Aficio 1060/1075. How do I do this?
  • jonahb79 Jul 16, 2009
    Thank You Very Much!!! This is the solution I needed and it worked like a charm! Thank You Again!
  • 204 Answers
You cannot restore the key operator code for the Aficio 1060/1075. You can delete the code and then write new one .
Follow the instructions and will be easy.
1. enter the service mode.
2. To enter the service mode press one after other the follow keys on the control panel of the copier.
press the yellow key [ Cancel Modes] than press the number one after other [1]-[0]-[7] on the number keypad of the copier and than press and hold the red key [ Clear \ Stop] until on the touch screen do not appear the service menu after the service menu will appear press on the touch screen [Copy Sp] up in the right corner has a touch key [sp direct] press that key and press the follow numbers on the number keypad which are 7810 and then press "#' on the number keypad.
on the screen will appear "execute" press the touch button and than by pressing
"exit" several times you will exit from the service mode.
NOTE: "PLEASE DO NOT TOUCH NOTHING ELSE IN THIS MODE IF YOU ARE NOT A SERVICE TECHNICIAN BECAUSE BY PRESSING SOMETHING YOU MAKE SOME ERROR OR OTHER PROBLEM"
After clearing the key operator code you may enter new one.
If you need something else please ask
PLEASE RATE ME
Posted on Jul 15, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How can i go into service mode?
press clear mode then press 1 then press0 then press 7 then press stop button hold down for 5 seconds should see display say 1copy press 1 then press 7 ok then press 810 press ok follow instructions.
Apr 04, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
Retrive lost activation code
activation code is the code you put in for the program.
ex. windows has a key code for that particular "windows"
to activate it. There are some other programs like Norton or
McAfee or whatever else that require a code to activate.
Apr 17, 2013 | Microsoft Windows XP Professional
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
WELL I LOST MY KEY CODE AND NEED TO INSTALL MICROSOFT 2000 PROFESSIONAL .CAN YOU HELP ME OUT TO FIND IT.
If your MS Office 2000 is still on your PC. You can download key finder program like "ProduKey" by Nirsoft or "magic jelly bean" program to retrive or extract the serial code.
Jun 01, 2010 | Microsoft Windows 2000 Professional for PC
Key codes wore off sticker can I retrive ?
There is no option available to retrieve the product key of the Operating System. However, the version of Operating System can be found in System Information page. To view this, perform the below steps:
1. Right click on ‘My Computer’
2. From the drop down list click on ‘Properties’.
This will open the System Information page where the version of installed Operating System.
Further, your PC is shipped with OEM version Operating System and that does not require an activation when reinstall from recovery manager. However, if it prompts for a product key, then contact HP.
May 26, 2010 | HP Pavilion 110-1030NR Notebook
I have the disc but can't find my 25 key product code
You will need to contact HP/Compaq to retrive your key code or purchase a new os. Sorry.
C2Solutions
Jan 16, 2010 | Compaq Armada M700 Notebook
How can I add or delete users for scanning? (Ricoh Aficio MP 5500)
Programming is under:
"User tools"
"System settings"
"Key operator"
"program/ change/ delete user codes" (or similar)
*please rate solution
Apr 14, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
589 people viewed this question
k24674
jasbo
jasbo
