Question about Blue Sea Sea 3082 Dc 10 Position Toggle Branch Circuit Breaker Panel
Circuit breaker for airconditioner keeps tripping we have central air
    Problem Solver:
  • 7 Answers
If the circuit breaker trips right away then I would suspect a dead short somewhere. If the unit runs a little then I would check the contactor at the unit. Turn off the breaker and activate the contactor a couple of times. The contacts could be a little sticky. Hope this helps.
Posted on Jul 23, 2009
    Problem Solver:
  • 18 Answers
You really need a service guy sorry
Posted on Jul 18, 2009
How do i fix my central air conditioner from tripping the circuit breaker?
tripping circuit breakers indicate shorts in the system or overload from a compressor failure
call in a technician to properly diagnose the problem and get a quote
Jun 01, 2016 | Heating & Cooling
We have a 1999 "Thermal
DO NOT install a 20 amp breaker, you can cause a fire. The breaker is rated for the WIRES, and unless you change out the wires, the 15 amp wires will overheat and can cause a fire.
Typically, A/C units need dedicated power, with nothing else on that circuit.
One step that you may try is a new 15 amp breaker. Once a breaker starts tripping, is starts tripping earlier....
You may wind up running a new circuit for the A/C, if you do, size it for the A/C.
Jul 18, 2011 | Heating & Cooling
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
The furnace part of my central air is wired to a seperate breaker but keeps tripping the breaker and making a spark in the breaker box.
Usually a Central Unit is wired seperate, the Air handler inside and the
Cooling unit outside. It appears that the breaker is bad, is it a Single Pole Breaker?
Another possibility is that the indoor blower motor might be bad.
Jan 10, 2010 | Heating & Cooling
Air conditioner trips circuit only in the evening?
first off, it's illegal to release freon into the atmosphere. the epa could charge you $32,500, so keep it under your hat. second, if it's getting too cold where the evaporator coils are icing up, it's too lille freon, not too much. as for the breaker tripping, your compressor might be wearing out. if it's pulling too much current, the motor is failing and the compressor needs replacing. and do not do it yourself unless you're certified by the epa to move freon and have the proper equipment to recollect the used freon.
Jul 29, 2009 | Heating & Cooling
Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Jul 22, 2009 | Weather King 10AJA6001AH Air Conditioner
Central air conditioner keeps tripping breaker
first when you reset the breaker stand off to the side circuit breakers can explode i've seen it happen sevral things will cause this 1 a shorted compressor. bad start components or contactor if compressor is pulling locked rotor amps you need a compressor a stuck compressor can some times be un stuck. you need a cotractor. Tom
Jun 18, 2009 | Heating & Cooling
Air conditioner pop and then blew refriderant or something
Inspect the capacitor for failure. if it is not swollen or leaky then the compressor might be gone.264f733.jpg
Jan 08, 2009 | Kenmore Room Air Conditioner
Blue Sea Sea 3082 Dc 10 Position Toggle Branch Circuit Breaker Panel Logo
139 people viewed this question
Top Blue Sea Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Blue Sea Boating Expert? Answer questions, earn points and help others
