Question about Maytag Neptune MAH5500B Front Load Washer
Not spinning to spin-dry clothes.
My Maytag Neptune Washer will pump out the water, but not go into the spin cycle to spin out the major part of the water from the garments. What might be wrong?
  • 92 Answers
First check the motor bushes they are more than likely to of worn.
Posted on Jul 15, 2009
MAYTAG NEPTUNE FRT LD WASHER MAH8700AWW,NOT COMPLETELY THE SPINNING/DRAINING CYCLE,LEAVING CLOTHES VERY WET,WE SELECT SPIN CYCLE ALONE FOR EST. 9 MIN., THEN DRY, NEED A FIX - HAVE ONE ?
Check that the pump is operating properly. hold the drain hose over a bucket during pump/spin make sure its a reasonable output from the pump..If not remove and clean your filter, then readdress problem as before, if still no cure then check the pump blades are free.....If all is well and pumping okay then spin should be fine providing the motor is okay......Good Luck.....
Feb 16, 2011 | Maytag Washing Machines
My neptune won't spin during the spin cycle Water left in the basin clothes are soaked
could be a bad pump or something in the pump like a missing sock it wont spin unless the water is pumped out
Nov 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune FAV6800AW top load washer will not go into the spin cycle with clothes in it. It stops at 12 minutes and then we get a DC error code. When you take the clothes out, it finishes up the...
if it spins when you remove the wieght out of the tub i'd change the belt and if that's not the problem the tranny is bad but try the belt first,most likely that's what it will be,stop overloading the washer the part number for the belt is 25001054 and it's around 15 bucks
Oct 22, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
Maytag Neptune Washer Problem
replace the door latch wax motor and check the drain pump for obstructions.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
404 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
