Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Flashing red power light - Sharp Aquos LC-42D62U 42 in. LCD HDTV
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
Red light flashing
Power off your printer, open the cartridge lid; take out the cartridge and put them back again.
Power on your printer and check whether the red light still flashing?
For further assistance, you can also avail our technical support services by visiting our website: http://www.vtechsquad.com.
May 20, 2013 | Epson Stylus C60 InkJet Printer
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
Tvstopped working, green power light comes on, red light flashing
Most likely it has a power supply module problem. Have it looked at by a qualified service company.
Dec 08, 2009 | Sony Televison & Video
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Power Light Flashing Red
Change the lamp. If red led is flashing 4 times. replace lamp fan.
Apr 22, 2009 | Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
162 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
