Question about Raypak 130,000 BTU Propane Gas Pool H...
Raypak 5100c won't light. the board is new. the
Raypak 5100c won't light. the board is new. the honeywell ignition module is new. when the 24v terminal is hooked up to the ignition module the volts drop to 18v. at the ignitor
  • jeff ross May 11, 2010
    what,if any messages show up on the display board?i.e.CLK,CFH,PRS or SPK
  • 128 Answers
Bad ignitor
Posted on Aug 30, 2009
Automatic pilot light wont light on a honeywell furnace
Honeywell is a controls company and makes a variety of auto-pilots. If this is a no spark problem,does the lead from the igniter go to a big PC board or a module. If a module, check voltage to the spark module or thermostat voltage to the ignition module. If it comes from a large board, the board may be bad. I'll need more Info. if this does not cover it for you.
Nov 18, 2013 | Honeywell Power Humidifier: Furnace...
I changed a honeywell thermo last night. I'm
check your transformer some of them have a little reset button on the side if it arched it could of tripped it.if there is no reset make sure you have 24v coming into thermostat.
Apr 22, 2012 | Honeywell Heating & Cooling
Raypak 2100 265A displays GVO. I know it means Gas Valve Open, but I do not know what is wrong. It is a IID Electronic Pilot. I see a slight flame when the igniter lights and then the system goes into GVO...
Here is the directions from raypak on this code.
1. Turn off power and disconnect ignition wire and gas valve wires from cpu board.
2. Turn on the power and watch for spark at module.
3. If no spark is observed, turn off power and replace the board.
4. If spark is observed, turn off power and reconnect gas valve and ignition wire.
5. Turn on power and unit should fire.
if unit does not fire and code reappears, turn off power and disconnect gas valve wires from the board and remove MV,PV and ground wires from the gas valve. Clean and reconnect wires.
7.Plug the gas valve back into the board and torn power on. Unit should fire.
8. If the unit fails to fire, Replace the gas valve.
Its not a good code to get. Hope this helps
Mar 21, 2011 | Rheem Pool & Spa
Pool heater getting only half of 24v
bad transformer or wiring if new and 120 volts see inside front cover for wiring if old replace transformer
Apr 28, 2009 | Raypak Pool Heater Covers for Teledyne &...
Ruud urgh07e36jkr heater wont turn on
Well I checked and the pilot would light and then go off right away and repeat.I jumped the 24v terminal to the pv pilot valve terminal on the ignition module and the main burner lit up. I then disconnected the spark igniter and the burner shut off and it tried ti relight producing hi energy sparks from the ignition module. So I ordered the module from american hvac parts online and replaced it. I recieved an updated module and had to hook up the 24v to the th-w terminal to make it work the old module was a s86ooh
And i just searched the new model number to figure out how to make it work. The new one has self diagnostics on it. It cost 208$ with shipping
Dec 11, 2008 | Ruud UAMB Air Conditioner
Raypak 130,000 BTU    Propane Gas Pool H... Logo
162 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
