With AV2 stereo input work the Front Right speaker and the woofer. With radio tuning work the FL, FR speakers and the woofer. With a DVD Dolby digital, no sound. Is possible a schematic diagram?
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
SOURCE: I just purchased a Toshiba HD A20 from Best Buy but the unit didn't have a user manual
Go into the menu options for the player, and switch to Bitstream! Not PCM
SOURCE: Toshiba HD-A30 won't play digital sound with HD DVDs
Try checking your audio output in the setup screen of dvd player. Try setting Digital Out HDMI to Auto, if it isn't already. See if that helps.
SOURCE: out to speakers only in 5CH mode, or front L/R
set it on dolby digital mode not sterio mode should be differnt modes on a ch only use prologiic or spin the mode dial to doby digital on movie on direct tv wont be dobly fake suround more less but center should work change settings modes
SOURCE: Cannot get surround sound even
Which model are you pertaining? try this links
http://usa.denon.com/AVR-1707-OM-E.pdf
http://usa.denon.com/AVR-1507-OM-E.pdf
http://usa.denon.com/avr2803_ownersmanual.pdf
chances are surround modes are not set properly and check on the cabling as well, this manuals will give you guide for it.
