SOURCE: My iron shuts off when I am continuously ironing.
The flashing is a indication that somthing is failing.. More than likely it is a internal component..
It might be most efficent to get a new one..
Or bring it back if it is under warranty..
Good luck..
SOURCE: D2030, Digital Iron - display lights up, but the
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
SOURCE: Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's
suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and
your clothes so don't fill the iron with softened water. Instead, use
filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
