Question about Sony PlayStation 2 (PS2) Console
Playstation 2 the connections cords in the back appears to have a short. sometimes the game comes on and other times we have to move the cords around to get the game to come on.
  • 709 Answers
Hi Jlewis06,
The Big Size PS2 does not usually have any problem with this.If you do have the Phat size PS2, the power connection is easy to replce and you can get another one on Ebay relatively cheap. I do believe you have a Slim PS2. The slim does have a high rate of failure in the power Socket. It either needs another motherboard, or the Power socket needs to be resoldered carefully or replaced. You can Click on the "Repair Directory" link at the bottom of the page and look for Video Game console repair.
Posted on Nov 17, 2007
Why won't my playstation 2 turn on?
its probably because it is 15 years old old wiring tends to short
Dec 29, 2015 | Sony PlayStation 2 (PS2) Console
Hi. My son's Playstation 3 will not work! I was running and update and I watched it get all the way through 100%. It then turned to a grey screen and kept doing nothing. I eventually turned it off,...
Are you seeing anything onscreen apart from the grey screen?, also check all cords are securely in sometimes they move just enough not to show picture
Jan 01, 2015 | Video Game Consoles & Games
My ps3 turns on but no picture
First, how are you connecting? RCA jacks(red yellow white cords) or HDMI? If it's the RCA cords, they were known to develope shorts in the yellow cord that connects to your TV. Just try another cord. They are very cheap, and the cords from all of the other Playstations will work for the PS3. Second, try to do a picture reset on your system. Sometimes, going from HDMI, back to the RCA confuses the system because the RCA connections are NOT detected automatically, HDMI is. To do a picture reset, turn the system on, then push the power button once,(you'll hear a beep) then push and hold the power button until the system shuts off.(you should hear 2 beeps) Then when you turn the system back on, the picture will be reset. ^^ Good luck, and I hope this helps.
Dec 06, 2014 | Sony Playstation 3 (PS3) Console
Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
Feb 05, 2013 | Sony PS3 DualShock3 Wireless Controller...
We think there is something wrong with the video and audio plugs, that go into the tv. But were still not sure. The playstation does turn on we can hear it. But it will not appear on the tv. When I say we...
Hello, To test what the problem is, I would recommend finding a friends whole also has a PlayStation 2. Offer good company and maybe lunch to bring his/ hers PlayStation 2 over. I would then attempt to plug in the friends PlayStation 2 into your TV and attempt to play a game, If It does work then you know the problem lies in your personal PlayStation, If it does not work then the problem could lie within the TV's internals, Possible the component connections. Assuming the game does play on your Tv, I would recommend using some tape to mark your friends cords, console and power supply (don't want to mix them up) and then start by using your friends Cords one at a time to see if you can get your console working properly. Probable can skip the power supply because you mentioned you can hear the driver start.
Best Wishes and Good luck!!!
Apr 10, 2011 | Sony PlayStation 2 (PS2) Console
Playstation 2 comes on for short time then quits?
My cousin was having the same problem with his PS2 coming on then going back off. Upon further investigation, it turned out he was holding the power button too long and was essentially turning on and back off. I hope this helps.
Dec 05, 2008 | Sony PlayStation 2 (PS2) Console
replace the audio video cord connector that connects from the back of the game console to the TV your cord pobably has a short.( the cord with yellow,red and white connectors on it).
you can get a replcement cord at gamestop, walmart or target
Jan 17, 2008 | Sony PlayStation 2 Slimline Console
Disc tray
yes you did.. on the back of the tray there is a wheel that has teeth like a gear.. it moves the lens/laser assembly up and down.. take a little time.. for the fine tuneing. look around on the back real good i have seen white,gray and black adjusters ..
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
