Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Belt slipping when in heavy grass. Is there an adjustment for belt tension?
    Problem Solver:
  • 13 Answers
This belt streching thingy is a made up fairy tale,that dealers want you to believe..so youll buy more belts...do belts really strech..?
ya..a little..but id bet your real culprit is the pulley..there is a tention spring that usually gets knocked out of place..or there is a build up of grass hindering its progess....your answer...no there is no adjustment...
drop your deck to its lowest setting and play around with that pulley till you see it getting tighter...then engage your deck blades(with the mower turned off)and move the pulley to free it from its off track position..take out the grass thats collecting in there also(dont roll it up and smoke it)
and you should be fine...good luck...ive been there..actually last week i did the same thing...the first thing i thought was...My belt stretched...lol
Posted on Aug 14, 2009
    Genius:
  • 1,036 Answers
It could probably benefit from fitting a new drive belt, as they do wear and stretch.
This should fix things.
Try to mow late in the day - and avoid wet grass. If it is too long - you need to mow more often as there is a limit as to hight it can cut without problems.
The belt is designed to slip at a certain load - otherwise the engine will stall.
Posted on Aug 11, 2009
Have the same problem
Posted on Aug 03, 2009
Why does the belt slip forward when I run on it?
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Sep 15, 2015 | Exercise & Fitness
My Poland pro mower stop pulling while I was cutting grass the belts are not broke does it meed fluid in transmishin
There is a tensioner pulley that adjusts the belt tension, also if the belt is worn it will slip. Check it and look a how deep the belt is riding in the pulleys. The belt should ride in the pulley and have I/8 inch of the belt sticking out of the pulley.
May 07, 2014 | Garden
Belt keeps slipping on treadmill
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Alternator belt tension?
alt belt has a slip torque adjuster. belt should be set to 1/4 to 1/2 inch deflecting pushing on the belt between the longest distance between pulleys. more than that will put to much tension on the belt and less than that will cause it to slip when wet or under heavy acceleration.
Mar 21, 2014 | 2005 Dodge Neon
Walking belt slipping
Dec 22, 2013 | Precor Exercise & Fitness
Precor c944 treadmill belt slipping
Feb 05, 2013 | Precor C944 120 Vac Version 1 Treadmill...
Can't get enough tension on pto belt
make sure you have the proper belt
Sep 23, 2012 | Garden
Why do cutting blades start slipping in heavy grass?
either the engine speed is to low or the belt is slipping how old is the belt is there a oil leak that got the belt wet with oil?
May 20, 2012 | Garden
I have a cub cadet ztr 50 and the pto clutch slips when in heavy grass
A PTO clutch can wear out and slip, but how have you determined it's the clutch internals, and not the mower drive belt that is slipping? Take off the mower drive belt and inspect it. Make sure it's not worn out or stretched. Make sure the spindles and pulleys turn freely and aren't frozen or binding. When you reinstall the belt, check the tension on it -- usually shouldn't be able to deflect the belt more than about 1/2 inch with strong thumb pressure. Some mowers use two springs to tension the idler pulley. If one spring has come undone or gotten lost, you'll get slippage. If all that is OK, then you may have internal slippage in the clutch. Removing and disassembling the clutch can be challenging, and replacement is expensive, so check for more common problems first.
Aug 16, 2010 | Garden
Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
505 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
