Question about DBX Driverack-Pa Eq/Speaker Control System System
When going through the driverack pa setup wizard, where is the "custom" speaker setting?
    Scholar:
  • 32 Answers
You should be able to spin the dial all the way to the end of the list of speakers and there you should see custom.
Posted on Feb 06, 2010
  • Greg Lind
    Greg Lind Feb 07, 2010
    Oops, I hit post a bit too soon. If for some reason you can't find custom, as long as you use the auto EQ and follow the directions to set up the gain it doesn't really matter which speakers are selected because you should end up with the same sound either way. What you'll get either way is a "pinked" EQ and an optimized gain structure.
    Check out this site, it's very helpful:http://www.driverack.com/drug/
    PS the "drug" at then end stands for Drive Rack User's Group.
Good day..The common problem in a closed pa system setup is feedback.It limits the capacity of unit to give a higher intensity of volume..With this I just want to ask if DBX Driverack pa+ will work well...
The DBX driveracks work well with about any PA. The only PAs you might encounter a problem with would be one of the newer line array and digital processing PAs. Let your audio person get creative, the presets for multiple PAs are just a guide. If your sound person is confident and is qualified, let him/her experiment and/or rehearse - you'll be amazed at what that system is capable of.
Mar 10, 2011 | DBX Driverack-Pa Eq/Speaker Control System...
DBX Driverack PX "Wizard" not allowing MONO
set it up as mono=common leads together and l,r,leads together,it will see left and right are in use and should load up
Jul 05, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
DBX PA+ no settings for Yorkville EF500P and LS801P
yeah that is because Harmon makes JBL speakers and Crown amps..for Yorkville Speakers use the VTC DLMS4080 Speaker processor, it blows the Drive PA away...
May 05, 2010 | DBX DriveRack 480 Processing Unit Home...
Setting up rta on a driverack pa, system willnot
As far as I know, you just turn the dial so that you can hear the pink noise at what you expect to the the normal listening level, hit "next page" then the system starts "listening" and adjusting automatically. If you set the RTA to high resolution it can take a while. At this point you shouldn't be trying to hit next page. Just wait for a while. Maybe 5 to 10 minutes if you're on high resolution, depending on your room and setup. Let it go through and EQ. After a while you'll get a black progress bar at the bottom of the screen, sort of like a file download progress meter. Let it finish. If it's taking too long check the manual for how to change the auto eq to low or mid resolution.
I hope this helps. From your post I can't tell exactly what's going on. Reply with more info if you like and I'll try to help again.
Dec 06, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
Can someone help me how to custom set my Amp & speaker in a dbx drive rack system
By far the best way to do this is to have an RTA microphone. Set speakers and amp to custom, then run the wizard to pink the room. Then make sure to set up the gain structure (pg. 41 of the manual available online).
Although it's satisfying to see the name of your speakers and amp listed, if you follow the procedures above you'll end up with the same results -- a properly EQed room and an optimized gain structure.
Oct 26, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
We have a dbx Driverack PA unit with a Crown CDi1000 amp in our church. Recently, we starting having problems with the output to our main speakers dropping out. We found (by accident) that if we unplugged...
Check the speaker wires coming out of your amp. Chances are you have a problem with a speaker wire and this is just a coincidence. I say this because the same thing happened to me during a live show and I about had a heart attack. We lost the front of house for about 15 minutes while I tried to troubleshoot the Driverack, the board, and everything but the speakers and speaker wires. The cables were a recent purchase and were premium grade with light wear so I mistakenly ruled them out. It was intermittant so it took me a while to figure out. Now I understand that that's the weakest link in the chain and from now on I start there and work backward through the chain (that is, if all sound is cutting out).
Do you use banana plugs (two metal pegs sticking out of a plastic rectagle) coming out of the back of your amp? There are little screws inside the holes on the back of the banana plugs. Those can vibrate loose, especially if they're just factory tight. Get a little standard screwdriver and tighten them down. That will probably solve your problem.
Okay, wait a minute -- could be one more thing. You mention that the loud popping can be heard. Do you have any gates turned on? Most compressors have gates. Check your compressors to see if you have your gates turned up too high. A gate set too high would allow the loud pop to go through to the PA but would cut off everything low to mid-volume.
I guess you can see that I don't think it's a problem with the Driverack. I don't work for dbx or anything, I just think these other things are far more likely than a problem with the unit.
Jan 02, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
DBX Driverack-Pa Eq/Speaker Control System System Logo
483 people viewed this question
Top DBX Audio Players & Recorders Experts
Philip Rowney
Philip Rowney
Vito Vacirca Jr.
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
