Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher stopped working...
No Lights on panel... Checked ciruit- OK... Plug has power... Water in bottom of unit... did not drain completely on last cycle.
  • 6 more comments
  • badgerguy Nov 19, 2007
    BTW, must have been a time bomb, cuz mine stopped working on 11/17/07 as well. It worked just fine for a little over a year with the "hotter" fuse, but I cant just keep dropping $100+ to fix a $250 unit.
  • Anonymous Feb 22, 2008
    no power at the circut board I pulled the wires from the white fuse on the control panel and put a jumper wire into the two leads and held down the door switch and it turned on and emptied going to but new fuse
  • kurtz2851 Aug 14, 2008
    My solution is to buy ANOTHER BRAND.....This unt is ONLY 18 months old and a 2007 model....So If I have it repaired for $150.00 and then another
    or the SAME circuit blows a year from now, I could have bought a NEW dishwasher with this outlay of resources...When my husband called Whirlpool's 800 line, they knew IMMEDIATELY that it was the circuit board...Logical deduction that this is COMMON with their units, and not an extraordinary problem...I have no intention of wasting any more of MY money to have it repaired...and my NEXT unit WILL NOT be a WHIRLPOOL dishwasher... It's a nice racket, if you can get it!!! They will not be getting THIS one....Donna Kurtz
  • jnjlowder Aug 15, 2008
    Same problem. It stopped working in the middle of a cycle. Checked fuse box, plug, they are fine. No lights on panel. Water in bottom of tub. Tried to check the fuse, but I don't have an ohm meter. just ran a wire from one plug wire to the other. No lights came on the panel. Tub didn't start draining. I did get a good shock when I tried checking the switch though. I have no idea. please help.
  • ROYTIG Apr 03, 2009
  • Anonymous Mar 13, 2014
    Hoses & clamps checked & ok. Water leaking from bottom above drain outlet. Serial no. FY1417627
  • Anonymous Mar 20, 2014
    power panel lights up, I can select a cycle, but it won't start, I do hear a slight hum, and there is staining water in the bottom from the last successful wash
  • Anonymous Mar 24, 2014
    My CDA dishwasher stopped half way through cycle, no power light, no lights at all, checked sockets all ok. Solution?
  • 290 Answers
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
  • Michael  Lindley
    Michael Lindley Nov 19, 2007
    Just wanted to follow up on you dishwasher and see what you found out.
    I agree with you about the cost of repair versus the cost of the unit. Most any appliance that cost less than $350 is a tough call on whether to repair or replace if you don't repair it yourself. The cost to have a tech come repair it will usually run 1/2 the price of a new one if not more. Since yours worked ok for a year then then there is either a different problem or something that is happening very seldomly to cause the fuse to blow. Also, the kit with the "hotter" fuse also has new wire ends with it due to loose connections causing the fuse to heat up and blow. I am finding many techs are not replacing the connectors which can cause a repeat failure. You could have a hi-limit thermostat on the heater sticking or a problem with the control or temp sensor. But unless it causes a problem with every use it is next to impossible to track it down. You could purchase the parts and repair economicly but the cost to have it repaired by someone else would cost more than the machine.
    Good luck with the new dishwasher.
Whirlpool gu3200xtxy I opened the door to add dish - it finished it's cycle andjust stopped working and there is no power going to unit. I checked circuit breaker and it's fine
test the pwr at the plug where it plugs in...if you have power..and lights on the front..then mabe a door sensor? if no lights..its replacememnt time..
Jan 08, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
We have a Whirlpool Gold Quiet Partner GU980SCGZ0 model. When rinse cycle is over the water only trickles out when draining. We checked the drain and it is not plugged. Water remains sitting in bottom of...
I took the check valve assembly off the bottom of the pump assembly and there was a big chunk of string balled up in the line which created a plug against the screen when trying to drain.Works great now!
Feb 15, 2010 | Whirlpool Dishwashers
Growing dishwasher
ok i will tellyou the secret. your unit is in drain mode .there is water in the base of your dishwasher and it has to dryed out to come out off drain mode. when you dryit then hit cancel and the unit will work. to get the water out you have to take off panel side to see the base. trade secret :0)
Apr 13, 2009 | Bosch 24 in. SHX36L05UC Stainless Steel...
No power to Selections, Water Did Not Drain
When you remove the bottom panel cover, check the wiring connection inside the junction box on the right for a loose or shorted wire.
If that's ok, open up the console and check the continuity of the thermal fuse that's clipped to the control board. Chances are it needs to be replaced.
Mar 05, 2009 | Dishwashers
Dishwasher stopped and will not start
Try jigling the ribbon cable that is connected to the control panel. These ribbon cables sometimes fail. Also check the fuse on the control board to see if it is blown.
Jan 02, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
Not Working at All
Check wire nutted connections where power cord connects underneath.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher stopped working
You have a board problem it came from a power surge.
Nov 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool GU2400XTP Built-in Dishwasher Logo
3,872 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
