After setting to wash unit will fill then cycle its self through all cycles without rotating or spining at all , and then drain , all in about 30 seconds. any ideas experts?
  • Phil Brantley
    Phil Brantley Jul 15, 2009
    it is an asko frontload washer model wm33 , a rare model to find I am finding out.
    thanks
    President:
  • 1,136 Answers
Hi, Is this a whirlpool model? Please give a model # so I know what machine you have for better instruction.
Thanks
Vic
Posted on Jul 15, 2009
  • Victor
    Victor Jul 15, 2009
    Oh, Yes very rare. I have never seen one of these. I will not be able to help you on this. you might need to ask the store where you purchased it and se if they have a service man. Try reposting you question again and include the make and model in your description. There most be someone on here that knows your model.
    Vic
Can you tell me what error code E12 is on a Bosch vision 300 washer?
I am not quit sure if my answer will help you, but I am going to tell you the cycle
The unit fills to whatever water level you choose to use
After reaching the water level the the wash begins, after 20 or 30 minutes of washing it needs to drain the soapy water. The drain pump turn on draining the water, after draining the unit fill back up to the settings and or sprays water while doing the draining and spinning to remove as much dirty water as possible from the first wash. After the first draining, fills back up again for the final rinse and the final drain
The symptom you are describing, here tell me, that issue is with the drain valve, drain hose, the sewer, or is a big possibility that there is is a sock or woman garment stuck in inside holding the rotor causing the water not drain inside the water valve, if the sensors are not sensing the opening of the pressure switch after the first fill. it will not continue This units lately has been added many sensors the only thing this unit doesn't has is the ability to speak but if using common sense you can get to the part that needs to be replace. You need to read and understand the wash cycle first.
Nov 24, 2017 | Bosch Washing Machines
How do I reset my KitchenAid Model KUDS35FXSS1
The unit normally has a 1:20 to 1:30 fill cycle with pauses in between while the wash motor starts and stops without running a diagnostic mode this normally happens when the control outputs power to the wash pump motor but the pump doesn't start
Sep 13, 2014 | KitchenAid Dishwashers
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
Kenmore Dishwasher
If you have either dry bearings in the motor or sticky grease buildup in the pump bearing/seal, it can cause the motor to stick rather than rotate on startup. More likely to be greasy crud buildup. The best you can do without disassembling the entire unit is to circulate a good degreaser product in a wash cycle, such as 409 or PurplePower. On the off chance (very small chance) it would degrade plastic parts, only run degreaser wash cycle for 5 minutes or so before draining it and running rinse cycle.
Nov 11, 2006 | Kenmore 24 in. 15149 Built-in Dishwasher
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
