Question about Nakajima AE-830 Typewriter
How do I program the typewriter to print out a preset file (for example, a form)?
    Genius:
  • 1,218 Answers
Visit web site www.nadist.com and download the operators manual.(FREE)
Posted on Jun 02, 2010
When I push the letter "G" , for example, a
If the printwheel isn't distorted or you aren't in KBII or a language mode the printwheel homing pawl is likely broken. You need a tech.
DickyO
Sep 01, 2011 | Brother GX-6750 Typewriter
How do you program the memory to store addresses?
On the L. dide of the keyboard are 3 keys, save, play and delete.
Hold the save key type an address 1 - 99 release the save key, type info., when complete press save again.
To print hold the play key and type the address. Delete works the same way.
DickyO
Mar 19, 2010 | Lexmark Wheelwriter 2000 Typewriter
Extra Line when printing from a dos-based program
your printer paper size shorter than your PC dos-program print size setting, example: if use a letter size paper to print a A4 size file which should occur two paper go out..
so you need check your PC print setting or take a presetting paper size, make a size match between PC program and paper in printer .
hope you fix it, please take a rating let me know how much helped you thanks!
May 21, 2009 | Dell 5100cn Laser Printer
How do I program my Swintec model 2640 typewriter to store information so that I can save it and press a key to automatically type the stored information?
The instructions to do this are located in your User Manual under "Create Text file" and "Print text file." It is too lengthy to write here. Check your manual, or if you don't have the manual, you can download one for $10.00 at www.typewritermall.com
Jan 14, 2009 | Swintec 7040 Typewriter
Won't print multiple copies
If this is a WW10 II using the code and Q will increase the impression. If this dosen't help some WD40 on the front of the print solenoid may help.
DickyO
Jan 02, 2009 | Lexmark Wheelwriter 10 Series II...
Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Lexmark isn't recognized by all my programs
May I suggest that you post this under lexmark printers rather than typewriters you will probably get better help.
DickyO
Jul 19, 2008 | Lexmark Wheelwriter 2500 Typewriter
IBM Wheelwriter 15 Series II-Program the memory
The WW15 does not have a recallable memory, it has a reprint memory that will repeat what you have JUST typed, code reprt top left kry on the keyboard will activate if you want a full memory get a WW5 or 6.
Dicky O
May 05, 2008 | IBM Wheelwriter 30 Typewriter
Re-print full?
The reprint automatically stores as you type. I dont believe it can be turned off, however if you use the SAPI feature it clears and starts over. SAPI Semi Automatic Paper Insertion. When inserting paper pull the rt. upper bail arm all the way forward it will indert paper to preset position and clear reprint memory.
DickyO
Apr 16, 2008 | IBM Wheelwriter 30 Typewriter
Setting HP OfficeJet 4315 print preferences on a MAC OS X
Whenever you send a file to print from a program a small window shows up. If it shows only
Printer: Drop down menu ARROW Presets: Drop down menu Some buttons at the bottom
then click on the ARROW pointing down for more options. That will show more info, including a drop down menu that will allow you to change page settings, printing settings, etc. For example, if you want to change the printing quality, select "Paper Type/Quality" from that drop down menu and new options will show up allowing you to change the settings of the printer.
Jan 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Nakajima AE-830 Typewriter Logo
50 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
