My needle is coming down a hair too soon so the bobbin hook misses the thread,
On the shaft that holds the needle you will find a clamp attached to a arm on a crank
if you undo that clamp it will slide up or down the shaft and that positions the needle
needle hook timing is on the start of the up stroke where the hook should be at are very near the eye of the needle
so position the shaft in the just up positing , undo the clamp and move the shaft ( not the crank) until the needle is correctly positioned and tighten the clamp
Testimonial: "I'm unable to access that part of the machine d/t lack of special tools to open. I was able to adjust the timing from below by loosening the 2 screws on the shaft that rotates the bobbin tray. When loosened the bobbin tray does not move when the wheel is cranked so I was able to place the needle in the correct position for the thread to be caught, then I re-tightened the screws. Mom always said, "There's more than one way to skin a cat." I guess she was right."
