Question about Kenmore Canister Vacuum Vacuum
How to open a kenmore powermate vacuum to replace belt
    Scholar:
  • 70 Answers
You have to take the light cover off (push in at the bottom on each side) and there are two screws.
Some models have pressure locks on the back of the power nozzel cover. Just use a screw driver.
Posted on Jul 15, 2009
SOURCE: Need to check belt on a Kenmore WhisperTone powermate vacuum
There are two screws. Pry off the light bar on top by pushing against the sides, and you will see them inside just behind the light bulb.
Posted on Jul 26, 2009
reddevil6
  • 1673 Answers
SOURCE: Kenmore Powermate Canister Vacuum Cleaner
Depending on which model, there is a couple of scres on the bottom, then on each side and back are release catchs that you pry up to release the top, then you can get to the belt. The other model you take off the light cover, it just snaps in place, then you can take out 2 screws from the top, on each side there is a slot, put a screwdriver up into the slot and pry out to release the tabs, then the cover comes off and you can get to the belt.
Posted on Feb 11, 2008
advacak
  • 125 Answers
SOURCE: I am trying to disassemble
Squeeze the sides of the lamp cover, and it will snap off. then you will see 2 screws under where it was the rest is obvious
Posted on Feb 06, 2009
SOURCE: Kenmore Model 116 PowerMate Jr stopped working
SJ, I jumped the fuse and all is working as you suggested. I see Radio Shack has 3 temp fuses available. Which one did you use. Thanks for the help.
Posted on Apr 30, 2010
SOURCE: Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
Posted on May 02, 2011
When vacuuming the belt stops turning
Your belt is probably stretched, replace it. Also check to be sure nothing is lodged in the brushes
Sep 03, 2012 | Panasonic Kenmore Canister Vacuum Hose 116...
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
How can I access the roller belt in Kenmore Powermate 116 53313305? with no screws. Does the entire black half separate from the blue half?
If there are no screws on the underside (like mine) you need to remove the top light cover. There are tabs on either side that need to be pressed in so it pops out. Under the light cover there are two screws located in the center. Remove those and the blue and black components should come right off.
Jan 31, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
How I replace the belt for Kenmore 116 3063500C ser M53101631
Turn it over and on the bottom are (2) screws. Remove those and the top cover will come off and you can access the belt.
Jan 08, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Apr 04, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Brush won't turn on my Kenmore 216.37035700 vacuum
Here you go
http://www.managemylife.com/mmh/owner_manuals/11796/KENMORE-Vacuum-Upright-L0712557?brand_name_search=Kenmore
Nov 07, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Broken vacuum
check the belt it may have broke or stretched out
Dec 31, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Kenmore Canister Vacuum Vacuum Logo
645 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
