Question about Fujitsu Siemens Computers & Internet
Do I need to update my bios to install a dvd burner
    President:
  • 948 Answers
Probably not, but each computer is different. If your current BIOS will not support your new device you might need to upgrade it.
Posted on Jul 15, 2009
Firmware update for LG HL DT ST DVD RAM GSA H22n
Obtain and install the newest bios update.
May 12, 2013 | Computers & Internet
Lg hl-dt-st dvd ram gh22ns70 after use alcohole 120% does not recognize dvd only cd
Uninstall Alcohol and see if it is an issue specifically with that program. It may not be compatible. You made need to update the firmware on the bios r the dvd firmware. You may also need to replace the entire DVD burner.
Oct 18, 2012 | LG GH22NS70 Super Multi Disk drive DVD RW...
Optiarc 7240 sata
Try updating the Bios , it should work . U can also update the Firmaware of the Drive using this link
http://www.sony-optiarc.eu/supportservice/downloads/fwdownloadpages/ad7240sfwfile.html
May 10, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
Samsung writemaster thinks its a cd drive
Has Bios Detect the Same? If so check motherboard/Samsung writemaster update bios/firmware.
If not reinstall DVD driver.
Nov 29, 2009 | Samsung Super-WriteMaster SE-S184M DVD-RAM...
Lg dvd burner
Cd/Dvd writter is also known as RAM (Random Access Memory). no need to worry about it. If u face any problem with that just go to its property nd update its driver in hardware section. Or just chk bios
Sep 12, 2009 | LG GSA-E60L 20x DVD?±RW USB 2.0 External...
Acer 4520 DVD driver problem
try to update ur BIOS by install this update from here
ftp://ftp.work.acer-euro.com/notebook/aspire_4520/vista/Bios/3632.zip
Jul 25, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Dvd player
try updating the driver for your player that supports windows vista. if the player is not detected in your vista but detected in your bios try updating your bios as well. or you can try to do a system restore by going to start all programs accessories system restore. choose a date which you believe your player to work fine.
Sep 26, 2008 | Samsung SN-S082D DVD RW Dual Layer Burner
Dvd/cd burner
Go to bios settings, usually you go there by pressing F2, or Del, etc , depending on your motherboard.
In the first bios page often you find installed drives, your dvd should be there.
On some motherboards, like many dell's PC MB, you need to do explicitly HDD/cd/dvd autodetections to have the DVD installed . In this case you need to locate the bios command saying autodetect disk drive. If the disk is not detected you may need to check the jumpers at the back of the dvd (eventually test it a Master on single cable). If you are using IDE ribbon cable check also that the cable is plugged in the right way.
Check this page for a general procedure.
Regards
Apr 13, 2008 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Unable to burn using a LG GSA H58N DVD burner
With the built in drivers for windows XP it can identify and use DVD-RW facilities of DVD burner. However depending on your bios your machine can fail to burn DVDs if your bios can not recognise that output.
While loading the CD that comes with the DVD-RW did you get an error message if yes then it means you BIOS is failing to recognise your DVD-RW as an output method try to update the BIOS. But before you do that if you can try adding the drive on a modern (after 2002) machine with xp and see if it can burn DVDs there without adding any drivers.
if it fails on that other machine then you can be sure its not your BIOS but a problem with drive (which I suspect most actually). But if it works then then you need to update your machine bios.
Mar 25, 2008 | Computers & Internet
Soltek SL-75FRN2-RL
viga driver for soltek p4 vma-m
Nov 30, 2007 | Soltek SL-75FRN2-RL Motherboard
Computers & Internet Logo
153 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
