Question about Sceptre computers5: X9 S-Naga II 19" SXGA TFT LCD DVI Flat Panel Monitor (Black or Silver)
Sceptre X9 monitor problem
When I turn the monitor on, it works fine, for about 1 second, then goes black. I can turn it off again and on again, and it does the same thing time after time. One second of good working, and then black. Any idea what's causing this?
  • 2 more comments
  • boneshackett Dec 27, 2007
    I have the same problem with the same model. if anyone has any info on how to fix this it would be greatly appreciated
  • jimmy_s17 Dec 31, 2007
    I do have exactly the same problem......Need Help ........Please
  • wanker39 Mar 05, 2008
  • billhelwig Mar 15, 2008
    have exactly the same problem, it used to happen only on occassion, them frequently. Turning off and on a number of times fixed it.
    But now that no longer helps.
Hy,
usually the capacitors on the inverter board for the backgroundlight
should be replaced.
good luck
hans
Posted on Aug 26, 2008
I powered the monitor off 1 evening after watching movies I was useing the monitor as a second monitor on computer doing multi tasks, but now when i turn it on i just get a black screen it lights up at...
Your computer may not be seeing your second monitor. Go to your display settings and see if you computer is seeing monitor 2.
A fast way to check is to plug this monitor in as your primary on the computer to see if it works.
Mar 09, 2010 | Sceptre S1902D 19" LCD Monitor
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Screen turns on 1 second then turns black
With a known working monitor try it on the computer. If the monitor stays on then you know the original monitor is bad. If the monitor goes off after 1 second again, then you know that the video card is bad.
Aug 19, 2009 | Samsung Computers & Internet
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Comes on picture perfect and then reverts to standby. Responds to initial signals from computer then reverts to standby. Switch it on and off and picture re-appears but again reverts to standby.
I have a Sceptre X9* as well, and I was able to fix it with a few capacitors (470uF -- 35V -- 105ºc)*. The capacitors were very visibly swollen on the top. Changed those out and works perfectly now.
The inverter capacitors in LCD monitors are the most common problem with the monitor turning off after a few seconds :)
*Note 1: I listed the capacitor I used, but verify the individual capacitors before you replace them.
*Note 2: The Sceptre X9 power power supply board will most likely have R88 and C65 removed; this is a factory modification that you will not need to worry about.
Mar 19, 2009 | Computers & Internet
My Sceptre X7 LCD computer monitor comes on at startup and goes black after about two seconds. I turn the monitor off and on again and the picture comes on foe about 2 seconds and then goes out again. The...
SORRY MONITORS R MONITORS THEY EITHER WORK OR THEY DON'T. WARRANTIES R THE BEST THINGS FOR MONITORS.HAVE U TRIED THE COMPUTER ON ANOTHER SYSTEM TO MAKE SURE YOUR VIDEO OUTPUT ON THE COMPUTER IS WORKING CORRECTLY
Aug 11, 2008 | Computers & Internet
Sceptre LCD - no display
I have same problem... just went off warranty and they won't cover it.. they want $100 for repair plus $35 shipping plus I have to pay to ship it to them... For $179 I can buy a new 19" with 3 year warranty...I wouldn't buy another Sceptre at half the price
Jul 13, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Same Flashing Problem
My Sceptre Komodo 19 would turn on for less than a second than turn off. Eventually, I could get it to stay up. But after a month, I couldn't get it to stay on anymore.
I found the solution on this website. There are some bad capacitors... 4 of them for about $2 worth. I replaced all four and the monitor works fine again. They are soldered in. They are polarized; they need to be installed the right way. The white stripe goes towards the “wall”.
2 are 470uf 25v and 2 are 1200uf 10v.
I ordered mine for about $10 with shipping from Mouser.com
661-EKZE250ETD471MJ1 and 647-UHE1A122MPD
Jul 06, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Computers & Internet Logo
406 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
