If your tanning bed is beeping and the lights are turning off but the fans are still running, it is possible that there is a malfunction with the bed's control system. Here are some steps you can take to troubleshoot the issue:
1. Check the power source: Ensure that the power cord is plugged in securely to the outlet and that the outlet is functioning properly. If you have a dedicated circuit for your tanning bed, check to see if the circuit breaker has tripped.
3. Check the bulbs: Inspect the bulbs for any signs of damage or wear. If the bulbs are old or have cracks, they may need to be replaced.
4.
5. Check the timer: Make sure that the timer is set correctly and that it is not malfunctioning. If the timer is not working properly, it may need to be replaced.
6.
7. Check the bed's manual: Consult the owner's manual for your tanning bed to see if there are any troubleshooting steps or error codes listed that may help you diagnose the problem.
8. Contact the manufacturer or a professional technician: If you are unable to diagnose or fix the issue on your own, it may be best to contact the manufacturer or a professional technician to assist you with repairing the bed
The humming noise and non-functioning fans in your Sunquest Pro 24RS tanning bed could be caused by several factors. Here are a few things you can check to diagnose the problem and potential solutions:
Check the power source: Make sure the tanning bed is properly plugged in and the outlet is providing sufficient power. Test the outlet with another device to confirm it is working properly.
Check the circuit breaker: Check the circuit breaker for the tanning bed to ensure it is not tripped or in the off position. If it is tripped, reset it and try turning the tanning bed on again.
Check the wiring: Check the wiring connections inside the tanning bed to ensure they are properly connected and not damaged.
Check the fans: The humming noise and non-functioning fans may be caused by a malfunction in the fan motor or the fan blades may be obstructed. Check the fans for any obstructions and test the fan motor with a multimeter to see if it is receiving power.
Call a professional: If you are unable to diagnose and repair the issue on your own, it is best to call a professional technician to service the tanning bed. They will have the necessary tools and expertise to identify and fix the issue.
In any case, it is important to exercise caution when attempting to diagnose and repair electrical equipment. Always unplug the tanning bed before attempting any repairs and do not attempt any repairs if you are unsure of what you are doing.
I was able to find you a PDF Manual for the tanning bed model you listed, the key to looking for it online was to enter Wolff Sunvision Tanning bed......without the Wolff part it didn't come up.
Hope this helps and good luck!
Wolff tanning lamps
give off UV tanning rays like the sun but only UVA and UVB rays to help tan
without increasing the risk of burning.These are the type of tanning beds that most salons use.
A tanning
bed is a type of bed (with a top and bottom part to it) that tans the user
through ultraviolet radiation. There are tanning beds in salons but also home
tanning beds which tend to have less lamps and use less watts.
Consult manufacturer. You can track that down online. You may have a over-temp switch inside the bed. If so, then either the switch is bad or the bed is getting too hot. Have a trained technician to check voltage going to bed, if voltage is wrong that can cause bed to overheat. Make sure all fans are running, replace any fan that is not running. Clean all dust out of bed with vacuum and brush while you have it open.
Most Likely a bearing is going bad in the fan - unfortunate with such low hours - but probable. Make sure nothing is hitting the fan blades on either side of the fan - if not, then definitely a bad bearing and the fan will need to be replaced. Wolff Tanning carries them in stock at www.wolfftanning.com
