Question about Huffy Alpine 24 Youth All-Terrain Bicycle
Operator manual for huffy crosswind bike grip shift
Looking for operator manual to know what shift gears are on the grip shift 12 speed huffy crosswind womens bike
    President:
  • 1,138 Answers
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Posted on Jul 17, 2009
Have an older Huffy female 12-spd road bike that is missing the rear wheel assembly. Looking to find a replacement as well as instruction manual...wheel assy. more important. Thanks.
Unless you have a deep sentimental connection with the bike, it may not be with it:
Rear wheel - $35-$45
Rim strip/tape - $1
Tube - $8-14
Tire - $10-20
Gear cluster - $25-40
New Huffy is about $150-250
You might be able to find a used bike or wheel at a garage sale that would work.
Sep 19, 2015 | Huffy Cycling
I just purchased a second hand 10 speed 26" Huffy bike and need to know how to work the gears
Web search "how to shift gears" and go to http://www.huffy.com/Support/OwnersManuals.aspx for there generic manual.
The web has all thwe answers. Just ask it.
Aug 12, 2011 | Huffy Cycling
I have a dynacraft magna great divide 21 speed mountain bike and don't know how to use it. There was no owners manual. I don't know anything about using the gears, could you please help'
Bikes is bikes so ANY owers manual would ge tyou through the basics.
TRy Huffy's. http://www.huffy.com/Support/OwnersManuals.aspx
Then, using a search engine, ask any question like "how to shift a bicycle" and videos will appear instantly.
This doecument will teach you a whole bunch of stuff about techniques and strategy for road riding.
http://www.johnforester.com/BTEO/ECIL.pdf
Jul 03, 2011 | Cycling
Using a Huffy Verona Comfort Series bike - how do you shift?
The same way they all shift (considering the different physical designs of the shifters). Each lever has a control for INcreasing required effort or DEcreasing it. They work opposite each other.
Get on a search engine and look for "how do you shift gears on a bike" for many videos.
Huffy has manuals, too.
Jun 30, 2011 | Cycling
For a Huffy Pro Beach Series bicycle model #56289K, I need a replacement Speed Grip Shift assembly for the handlebar.
Identify the brand and model and hit the search engines, eBay, call a Bike Shop. It will need to be installed. NO ONE sells just one side. Consider an upgrade since you may be purchasing both sides.
Even the Huffy site doesn't refer to the bike by model number. What's it called?
http://www.huffy.com/Support/MaintenanceDocs.aspx
Jun 27, 2011 | Huffy Cycling
I have a Huffy Savannah model 56770 16 speed. How do I shift into gear 7 through 16 ?
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you're having a problem with. Get behind the bike and look straight along the top of the chain. As you can see the line of the chain is a mild zig-zag where it is parallel to the bike at each gear but needs to angle across the drivetrain in between. On some bikes the chain might even come in contact with the next larger chainring when used this way.
The big-big combo uses up all available chain length and the rear derailleur will be pulled toward the front of the bike, sometimes so far that it is in danger of being snapped off.
THERE IS NO UPSIDE TO CROSS-CHAINING.
As you can see, the rear derailleur is probably not long enough to **** up all the slack this gear combination creates. There are other combinations that would yield the equivalent gear ratio without either stressing the drivetrain or dropping the chain.
The basics of shifting are these:
1) The big ring and right side of the cassette in back are for speed.
2) The small ring and the left side of the cassette are for high torque, lower speed
Ancient bike wisdom for beginners: If your legs ache, shift down. If your lungs ache, shift up.
Apr 25, 2011 | Huffy Cycling
I need an owners manual for a roadmaster mt storm by huffy
The best I can do is to provide you with the manual that Huffy provides for multiple bikes. The manual below is for multi-speed and freewheel bikes.
Huffy Multi-speed Manual
Hope this helps. Thanks for using Fixya.
Note: If the manual link above is not useful you may contact Huffy directly at:
Huffy Bicycle Company
6551 Centerville Business Pkwy
Centerville, Ohio 45459
(800) 872-2453 customer service
Monday - Friday: 8:00AM - 12:00PM; 1:00PM - 4:30PM EST
Jul 13, 2010 | Huffy Men Mountain Bike (26")
18 speed bike 6 gear shift works fine 3 gear
You have to look if when you act on the shifting level it get hard to move or it is free, if free, probably the cable is broken.
Also check if the cable is not too loose, try to follow the cable track and move the level and see if the cable move with that, in that way probably can find where the cable is stuck or broken/loose.
May 09, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
If the cable is rusty or otherwise binding it won't let the derailleur fall toward the smaller sprockets when the control is moved. Likewise, it may not even let you move the control in the direction that pulls the cable (bigger rings).
If you don't know much about the process I suggest you read this:
and take the bike to a Local Bike Shop for a look-see and maybe a tune-up.
Mar 16, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Huffy Alpine 24 Youth All-Terrain Bicycle Logo
1,166 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
