Question about Fossil JR8096 Wrist Watch
Hi the digital background on my fossil watch isn't working... but the analog is working fine, can you help
  • 2,334 Answers
There is another battery in your watch. One for movement, another for background. You have to replace background battery.
Posted on Jul 15, 2009
Replace fossil big tic battery
Little battery operates the analog. big battery operates the digital second hand on the fossil big tic.
Aug 19, 2013 | Fossil JR8096 Wrist Watch
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
Broken digital clock
First of all visit the FOSSIL site from my tips and tricks. If you can not find the solution there, check out if you have two batteries in your watch. It is quite common to have two batteries in Fossil watches (same do Timex). If nothing helps, you have to visit your nearest watch repair shop.
Jan 21, 2010 | Fossil Leather Casual Ana Digi Black Ip...
I just received one of these watches (or I believe thism is the right one-it IS fossil) How do I adjust thd date? I've looked for the watch online and this was they call this watch "Fossil Analog Silver...
Go back to the web site and at the bottom of the page in faint lettering there are a number of options; one of them is customer care and they have the downloadable instructions for their watches.
Choose yours and download.
Dec 31, 2009 | Fossil Watch - Analog Silver Dial
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
Lost Instruction manual
Try this link. It is for Fossil watches and you should be able to find instructions for you particular watch from the list of choices. I would look at the analogs and the multifunctions. http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Jan 07, 2008 | Diesel Audio Diesel Watch
Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Aug 29, 2007 | Fossil CH2331 Wrist Watch
Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Aug 21, 2007 | Fossil JR8096 Wrist Watch
Fossil JR8096 Wrist Watch Logo
824 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
