Fitted new belt now vcr wont do anything. apart from capstan occassionally turning and displaying eject. thanks
Whenever you work on a VCR, or the mechanism goes faulty, the mode switch - which tells the electronics what mode the mechanism is in - has to be set up correctly. This is a very complex procedure and unless you have done it before you will need a service manual. Mostly because the mechanism is rarely ever set up in eject mode. At the moment you VCR is trying to work out what mode the mechanism is and is trying to eject a tape, when the mechanism has already done so!
SOURCE: wont work
reset it by unplugging the power briefly. If that doesn't work, then it is detecting a mechanical problem inside and needs to be repaired.
SOURCE: safe!!!
Go inside and REPLACE e v e r y rubber band that u find in machine. Don't replace one or two, if you find one or two bad
REPLACE THEM ALL.
SOURCE: vcr stopped working. Time blinks whenever I press any buttons.
I took the cover off the vcr pushed on some random parts, blew some dust of it, and put it back together. It worked.
SOURCE: Fault F04
F04 is "loading lock". most likely problem is that the timing of the gears in the tape loading mechanism is mis-timed.
SOURCE: SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
• To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
